4000 ford pto sfaft problem
   / 4000 ford pto sfaft problem #1
pawpawtom
Ciyronelle Al.
Ford 4000
The pto sfaft on my 4000 ford came out while I was bushhogging. I need to know is there a retainer or anything that holds the shaft in that might have broken or come loose. Thanks for any help. PPT
   / 4000 ford pto sfaft problem #2
Which 4000? Pre 1965 4 cylinder model or post 1965 3 cylinder?
Always mention which.
If pre 65 it is a simple task to remove the 4 bolts in the flange and pull the flange, bearing and PTO shaft out.
There is a circlip that holds the bearing and oil seal into the flange that likely came out.
It is a post 1965 3 cylinder. Is the fix different?
MANTIS 155B LOT IDENTIFIER 248 (A53084)
MANTIS 155B LOT...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
20 ft Angle Boom (A53117)
20 ft Angle Boom...
Wacker Neuson DT08 (A50123)
Wacker Neuson DT08...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
