4000 ford pto sfaft problem
   / 4000 ford pto sfaft problem #1
pawpawtom
Ciyronelle Al.
Ford 4000
The pto sfaft on my 4000 ford came out while I was bushhogging. I need to know is there a retainer or anything that holds the shaft in that might have broken or come loose. Thanks for any help. PPT
   / 4000 ford pto sfaft problem #2
Which 4000? Pre 1965 4 cylinder model or post 1965 3 cylinder?
Always mention which.
If pre 65 it is a simple task to remove the 4 bolts in the flange and pull the flange, bearing and PTO shaft out.
There is a circlip that holds the bearing and oil seal into the flange that likely came out.
It is a post 1965 3 cylinder. Is the fix different?
JOHN DEERE Z530M LOT IDENTIFIER 78 (A53084)
JOHN DEERE Z530M...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
