4000 ford clutch will not release
/ 4000 ford clutch will not release #1
david mcgill
ford 4000
clutch will not release we do not know if it has the right clutch it has single clutch some tells me it must have double clutch:)
/ 4000 ford clutch will not release #2
a lil devoid of info there? what 4000 is this.. a 4 cyl pre 65 model with a 4 spd? if so.. it's a single plate clutch. heck.. a 4000 3 cyl w/ ind pto is a single plate clutch.
is it seized so that you can't shift it?
post back a LIL more info so we can help you.
soundguy
I need someone to tell me what clutch is the right one when i bought the tractor it had clutch problems so i bought every thing new it still will not work
/ 4000 ford clutch will not release #4
Still no tractor information, still no help from those who could.
Simple questions, 4 cylinder engine or 3?
How many forward speeds in the transmission?
/ 4000 ford clutch will not release #5
OP has two threads running with the same topic.. They should be merged.
From the other thread, he has an 8 speed 3 cyl diesel.
I'm going to assume it's an independent PTO, so that would be a single stage clutch? I'm not telling, I'm asking. LOL
Wedge
/ 4000 ford clutch will not release #6
Wedge
3 cyl 4000 8 speed would have a single disc and IPTO, correct.
He probably has the traction disc in backwards.
