4000 ford clutch will not release
/ 4000 ford clutch will not release #1
david mcgill
ford 4000
clutch will not release we do not know if it has the right clutch it has single clutch some tells me it must have double clutch:)
/ 4000 ford clutch will not release #2
a lil devoid of info there? what 4000 is this.. a 4 cyl pre 65 model with a 4 spd? if so.. it's a single plate clutch. heck.. a 4000 3 cyl w/ ind pto is a single plate clutch.
is it seized so that you can't shift it?
post back a LIL more info so we can help you.
soundguy
I need someone to tell me what clutch is the right one when i bought the tractor it had clutch problems so i bought every thing new it still will not work
/ 4000 ford clutch will not release #4
Still no tractor information, still no help from those who could.
Simple questions, 4 cylinder engine or 3?
How many forward speeds in the transmission?
/ 4000 ford clutch will not release #5
OP has two threads running with the same topic.. They should be merged.
From the other thread, he has an 8 speed 3 cyl diesel.
I'm going to assume it's an independent PTO, so that would be a single stage clutch? I'm not telling, I'm asking. LOL
Wedge
/ 4000 ford clutch will not release #6
Wedge
3 cyl 4000 8 speed would have a single disc and IPTO, correct.
He probably has the traction disc in backwards.
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2020 Bobcat T76 Track Skid Steer (A64047)
2020 Bobcat T76...
SET OF (3) BOX MOUNTS (A63569)
SET OF (3) BOX...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
COMBINE RIM FOR JOHN DEERE (A63291)
COMBINE RIM FOR...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
