400 hr service on a L4060
   / 400 hr service on a L4060 #11
Send the fluid to Blackstone for analysis. That will tell you how much life it had left and give you a baseline for future test results. I sample the transmission fluid on our car before I change it, that's a lot cheaper than changing it before it needs it.
   / 400 hr service on a L4060 #12
You will hear many opinions but I see no reason at all to be changing the hydraulic fluid at 400 hours. Why ? Who says ? Many things suggested in owner's manuals make little sense. Some good, some "maybe" and some silly.
I find my machine a LOT quieter and the HST more responsive after a complete fluid change.
You can save even more time and money by not changing filters too.
Maybe this is why I don't like buying used equipment...
   / 400 hr service on a L4060 #13
I use a 20 gallon screened oil tray on wheels. Low profile making it easier to get where you need it.
It has a drain valve making it easier to transfer waste oil back into the empty 5 gallon pails. I found this a lot less messy than juggling oil pans.
A LOT of fluid will come out the main drain and filters on my machine.
My M's both hold around 15 gallons of fluid each and I use a plasma cut aluminum truck fuel tank as a drain pan. Tig welded handles on it. It will hold over 20 gallons of fluid no issue and I use a Harbor Freight 10 buck battery pump to drain it. I did replace the D cell batteries with Li-Ion rechargeable ones as the pump eats regular D cells pretty quick. Nice thing about my M's is, there is only one drain plug other than the filters.
I do recycle the used oil in my waste oil furnace too.
   / 400 hr service on a L4060 #14
Pull a hydraulic line. Put it in the bucket. Work the lever to fill the bucket. Probably don't want to do that for more than a bucket & a half. Then drain the remaining 4ish gallons out the bottom manually.
I did my service today. I tried the pump and was only able to remove about 4 gallons. I removed the drains on each side of rear axle one at a time and was able to control the flow without making a mess. These were 14mm bolts. I drained my oil pan after each one. There's a larger drain, 24mm, that drains straight down. It was easy to screw the drain back in and empty my oil pan. It contained most of the fluid. I had to empty it twice on this drain plug.
I think next time, I will skip the pump. It's not as bad as I thought it would be. The filter had almost no fluid when replacing them. The total for filters and hydraulic oil was $690. This included an outer air filter and a fuel filter.
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2020 DRAGON ESP...
