400 hr service on a L4060
   / 400 hr service on a L4060 #11
Send the fluid to Blackstone for analysis. That will tell you how much life it had left and give you a baseline for future test results. I sample the transmission fluid on our car before I change it, that's a lot cheaper than changing it before it needs it.
   / 400 hr service on a L4060 #12
You will hear many opinions but I see no reason at all to be changing the hydraulic fluid at 400 hours. Why ? Who says ? Many things suggested in owner's manuals make little sense. Some good, some "maybe" and some silly.
I find my machine a LOT quieter and the HST more responsive after a complete fluid change.
You can save even more time and money by not changing filters too.
Maybe this is why I don't like buying used equipment...
   / 400 hr service on a L4060 #13
I use a 20 gallon screened oil tray on wheels. Low profile making it easier to get where you need it.
It has a drain valve making it easier to transfer waste oil back into the empty 5 gallon pails. I found this a lot less messy than juggling oil pans.
A LOT of fluid will come out the main drain and filters on my machine.
My M's both hold around 15 gallons of fluid each and I use a plasma cut aluminum truck fuel tank as a drain pan. Tig welded handles on it. It will hold over 20 gallons of fluid no issue and I use a Harbor Freight 10 buck battery pump to drain it. I did replace the D cell batteries with Li-Ion rechargeable ones as the pump eats regular D cells pretty quick. Nice thing about my M's is, there is only one drain plug other than the filters.
I do recycle the used oil in my waste oil furnace too.
   / 400 hr service on a L4060 #14
Pull a hydraulic line. Put it in the bucket. Work the lever to fill the bucket. Probably don't want to do that for more than a bucket & a half. Then drain the remaining 4ish gallons out the bottom manually.
I did my service today. I tried the pump and was only able to remove about 4 gallons. I removed the drains on each side of rear axle one at a time and was able to control the flow without making a mess. These were 14mm bolts. I drained my oil pan after each one. There's a larger drain, 24mm, that drains straight down. It was easy to screw the drain back in and empty my oil pan. It contained most of the fluid. I had to empty it twice on this drain plug.
I think next time, I will skip the pump. It's not as bad as I thought it would be. The filter had almost no fluid when replacing them. The total for filters and hydraulic oil was $690. This included an outer air filter and a fuel filter.
2019 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2019 Toro Z Master...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2131 (A58376)
2131 (A58376)
(INOP) TCM 15 - 700 SERIES FORKLIFT (A52708)
(INOP) TCM 15 -...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
40 Gun Fireproof Safe (New/Unused) (A59225)
40 Gun Fireproof...
