Backhoe 400 backhoe stuck cluch
/ 400 backhoe stuck cluch #1
hydro2
Karns City PA
Mahindra 4035
I have a friend with a John Deere 400 backhoe that sat about six months and now had a stuck clutch. Any suggestions other than splitting the tractor. It stuck another time and he spiked the breaks couple times and it unstuck. No such luck this time.
Thanks,
Mark
/ 400 backhoe stuck cluch #2
Only a thought, but had a similar problem on my new holland....
It could be a build up of dirt and rust on the clutch forks causing it to seize. Under the bell housing should be a "drain" - often has a linch pin in it, so allow water to drain out but (in theory) stop dirt getting in. Take the pin out (cut it if you have to) and squirt a lot of anti-rusting agent (WD-40 in the UK) - make sure you point the can towards the forks and NOT THE CLUTCH PLATE.
This worked for me several times, but eventually I still had to split the tractor and clean up the forks and thrust bearing properly.
Thanks so much for the reply. I will tell him. Thanks again.
/ 400 backhoe stuck cluch #4
Try removing the round inspection cover off the LH side of clutch housing and spray clutch/PP with brake cleaner.
Thank you so much. Will pass it on.
VERMEER FT100 MULCHER (A64277)
VERMEER FT100...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
Briggs and Stratton Generator (A65579)
Briggs and...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
14' Cultimulcher (A66408)
14' Cultimulcher...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
