400 amp service -- what is required?
   / 400 amp service -- what is required?
You won't use electric heat backups and the heat pump at the same time.....
Incorrect. When the heat pump defrosts the heat pump compressor runs (cools instead of heats) and the heatstrips come on. Boom -- Lots of electricity use for 2 to 5 minutes...
   / 400 amp service -- what is required? #32
I have a 400A service in my house...Just a 400A meter on the outside wall feeding 2 200A 42 space panel's in the house. No disconnects between the meter base and the panel's-just the standard main breaker in the 200A panel's.
The main reason for the 400A service is breaker capacity because you run out of circuits quickly with all the dedicated circuits required today.
QUOTE]
I have a very similar setup. I wired my house myself and wanted the power company to run larger wire down the driveway (about 500 feet). They would only do it if I went with a 400 amp service. Sooo...
I hired an electrician to hang & wire the 400 amp disconnect box. Inside there are current transformers that he wired to the meter box on the outside of the house. From the disconnect I feed 3 200 amp boxes and 2 100 amp boxes. I didn't need anywhere near the 400 amp capacity but I did have a load of circuits.
   / 400 amp service -- what is required? #33
See NEC 220.82
100% of Heat pump compressor, 65% of supplemental backup heat. If compressor does not run when supplemental is used, you don't add both.
   / 400 amp service -- what is required? #34
@thebowman: Depends. I have dipswitches on the unit that I can set which select if there is a 2-stage or 3 stage heat. 2 stage is the two speeds on the compressor. With 3 stage heat, you can set it up so that in addition to the heat pump compressor, the resistive electric strips run. The thermostats have to match (i.e. know or have their settings set for 3 stage heat). My main 5 ton unit uses restive electric for a quick warm up in the morning. My 3 ton for my work area does not since it has very few windows in it. If the power bill got to me, I could nuke the 3rd stage for the main unit and save about $20 per month during peak heating season. Typically, thermostats use 1, 2, and 3 degree difference between the call temperature (what you set it for) and the room temp to select how much heat to throw at the problem. Note also that when I have the dip switches in 2 stage mode, the system is smart enough to kick in the resistive electric if there is a compressor problem or a water temperature problem.
@roamer: The geothermal units uses about the same amount of power. For a given tonage, the compressors are the same. The water pumps that move the water in the ground loop about trade with the fan in the outside unit on a traditional heat pump. The savings are shorter run times of the unit when compared to an outside unit. Put another way, an air exchange heat pump in the San Francisco bay unit would fare about the same as a geothermal. A geothermal in New England would woop an air exchange. Most geothermal systems also have 2 speed compressors in them. I think the systems are overpriced due to low volume, and so the two speed compressor is an attempt to justify that. Biggest win of two speed compressor is when your cooling. At low speed you use less power but run longer which means you can take more water out of the air (lower humidity).
Another way to say this: I can get 98 degree air out of a register when it's 10 degrees out. That doesn't happen with an air exchange system.
Pete
   / 400 amp service -- what is required? #35
I can get pictures if you need them...
Kennyd, you on BGE or Allegheny? I know what you mean about running out of breaker space.
I had a neighbor put in two 200A panels once. Don't remember if it was a 320A or 400A meter base, but he ran from the meter base straight to each 200A panel. The utility did not replace the feed from the transformer to the meter base.
   / 400 amp service -- what is required? #36
BGE. I built my house so the feed was sized correctly from the beginning. I have a lot of 240v circuits wired so panel space get taking quickly.
Some 240v circuits include:
Table Saw
Cyclone dust collector
Mill
Lathe
Welder
Garage Heater
Heat pump x2
Attic Air Handler
Well Pump
Air Compressor
1 BaseBoard Heater
100A Feed to Subpanel in OutBuilding
Some Dedicated 120v circuits include:
Drill Press
Water Heater
Basement Freezer
Stove/Range
Refrigerator
Entertainment Center
Sewage Ejector Pump
Attic lights
Attic Outlet
Garbage Disposal
So, add it all up and that's why the 2 200A 42 space panels!
   / 400 amp service -- what is required? #37
Back in 1994 I bought a cottage that had 100 amp service with something like a 24 circuit panel. I immediately had the panel upgraded to a 200 amp 42 space panel. Shortly thereafter I built a 40 by 60 outbuilding about 375' from the main house. In the barn I installed a 100 amp 42 space panel that was fed by a 100 amp breaker in the new house panel.
I called the power company to up-size the pole transformer and service entrance wire to 200 amp and was told they would not do it until my actual use exceeded 100 amps. If it was a new service they would size it to the main panel breaker size but in the case of a remodel they go by historical use. I saw the potential for problems with voltage drop if I had "everything running" at the same time and challenged this decision. The response from field service rep was "when the transformer starts smoking give us a call"!
What is interesting about this is that the electric company sizes your service based on "typical load" and not connected load. However, when I built my new hose 4 years ago I found out the gas company sizes the meter to "connected device potential". I have 2 gas fire places, 2 overhead heaters in the garages, big gas water heater, professional gas cook top, gas furnace, 2 gas grills and a back up generator. I was told I had to go to a commercial meter and regulator!!!!
   / 400 amp service -- what is required? #38
We're averaging $260 per month heating and cooling about 6000 sq. feet
Well, that explains it.... our house is 1350. :eek:
$260 for that size home sounds very reasonable. We run around $100 electric in summer due to air conditioning, pool pump and chlorine generator. In winter it drops to around 40-50 for lights and small fans to circulate wood burner heat. I should average it out over the year to see what I get for a per month average. We backup heat, cook and make hot water with gas.
   / 400 amp service -- what is required? #39
eepete;1796140@roamer: [COLOR="Red" said:
The geothermal units uses about the same amount of power[/COLOR]. For a given tonage, the compressors are the same. The water pumps that move the water in the ground loop about trade with the fan in the outside unit on a traditional heat pump. The savings are shorter run times of the unit when compared to an outside unit.
Pete
OK, I admit it, I'm no expert BUT. . .
Given that we are comparing a geothermal heat pump & conventional air to air heat pump of the same size:
The units for a given load in the house will run the same amount of time. How could they not? The only thing that might affect run time would be if they were variable speed or multispeed compressors but lets assume we are comparing the same (geothermal & conventional) of whatever you want. ie If we are talking about 30,000 btu units and the house load at a given time is 30,000 btu/hour each unit will have to run continuously to keep up with the load. The savings comes from the much higher efficiency of the geothermal - it can provide this amount of heat while consuming much less electricity than the conventional unit. Its as simple as that.
As I understand it no. If the temp outside is 60F then yes since ground temp is about the same. At colder temps like 32F the geothermal is using 60F water whereas the air heat pump is pulling 32F air. The geothermal will run much less for the same heat output.
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
Bobcat A770 (A60462)
JOHN DEERE 744L WHEEL LOADER (A60429)
JOHN DEERE 744L...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2013 Frieghtliner with Altec Bucket Model LR760 (A56438)
2013 Frieghtliner...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
