4 Wheel Drive
/ 4 Wheel Drive #1
BCNU
Hopkinsville,KY
Kubota B2630
Are all the Kubota B series 4 wheel drive ? The brochure I have dosen't say.
/ 4 Wheel Drive #2
Not sure, But in my opinion a tractor is crippled without 4 wheel drive.
/ 4 Wheel Drive #3
The current models are designated by B or B(X). X = 4 Wheel drive.....
/ 4 Wheel Drive #4
</font><font color="blue" class="small">( The current models are designated by B or B(X). X = 4 Wheel drive..... )</font>
Not quite correct.
All the BX series (sub CUTS) are 4wd. The X does not stand for 4wd but stands for sub CUT.
All of the B series are 4wd except for the B2410HSE which is 2wd and I believe out of production.
/ 4 Wheel Drive #5
Actually, the BX series is smaller than the B series, and is considered a SubCUT line, while the B series is a CUT line. It appears that all of the BX's and almost all of the B's are 4WD. The only exception that I could find on the Kubota web site is the B2410, which is available in 2WD. Click on through to the Specification pages for detailed information on each model.
edit: Yeah - what Mad said! /forums/images/graemlins/wink.gif
/ 4 Wheel Drive #6
</font><font color="blue" class="small">( Not sure, But in my opinion a tractor is crippled without 4 wheel drive. )</font>
Depends on what your intended use is. With a small tractor, FWA (front wheel assist) is a plus as it compensates for the lower tractive effort but in larger, heavier units FWA is not always needed or wanted.
/ 4 Wheel Drive #7
Exactly. I have no use for a 4x2 tractor, but in many cases 4x4 is a hindrance. Best example is when a tractor is used as a "tow-motor" like at a boat showroom where a tractor is used to push/pull boats into a warehouse. Another would be a golf course where in some cases it's better to have wide, slick tires that actually spin on the grass rather than dig up precious turfgrass.
/ 4 Wheel Drive #8
</font><font color="blue" class="small">( Exactly. I have no use for a 4x2 tractor, but in many cases 4x4 is a hindrance. )</font>
There is a great little lever that disengages the front assist when it's not wanted. It comes standard on all 4WD tractors. Problem solved. /forums/images/graemlins/smirk.gif
/ 4 Wheel Drive #9
I leave my BX in 2wd till I need 4wd....I should rethink this, because most of my work requires it to be in 4wd with the industrial tires. That handy little lever does come in handy! /forums/images/graemlins/smile.gif as does the differential lock!
Snal~
UNUSED AGT ATK-B1000 TWO-POST CAR LIFT (A64281)
UNUSED AGT...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
Prime 283 (A64126)
Prime 283 (A64126)
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
PTO Driven Portable Water Pump (A64119)
PTO Driven...
