4 wheel drive
/ 4 wheel drive #1
coffeeman
Platinum Member
Hi all
I was wondering if I should use 4 wheel drive always while in field. I guess pulling a disk or a big brush hog in not so smooth soil would be a good idea to use. How about when pulling finish mower on level ground? Would it be less wear and tear to take out of 4 wheel drive position? Maybe a little less fuel usage? I looked in manual and I don't see anything about using 4110 4 wheel either way.
Cheers....Coffeeman
/ 4 wheel drive #2
Good question.
I don't put in 4wd unless I need it. Your proposal for field work is probably a good one to get more traction.
For rotary cutting, if I am in the woods, I use it as I back up hills and also drive up hills. On a flat field, I likely would not have it engaged.
/ 4 wheel drive #3
Some of the literature I have read said that you use less fuel in 4x4 since you get less slippage and the power is used more efficiently... You dont want to use it when using a finish mower since in a turn the front wheels can 'churn' up the ground..
good luck
brian
/ 4 wheel drive #4
I'm not sure which is really better but I have always left my 4110 in 4 wheel except when on pavement or travelling in high range- no matter what the surface. I have cut many, many hours of "yard" type grass and my tractor has never damaged any of the turf from turning- and with the grass here in Florida growing in pretty much soft sand, it would sure do it if it was a problem. Your front differential keeps it from doing it. I have the industrial tires on mine, maybe ag tires could give more of a problem, but I think that would come more from the lugs than the front assist. To me, it's more of a pain to put it in & out of 4x4 when you need it, have always had to rock mine back & forth between forward & reverse to shift it and if you're slightly stuck in a low spot or whatever, you're going to cause more damage than if you had it in 4x in the first place. Just my opinion but it's always worked for me.
/ 4 wheel drive #5
I often leave my front wheels locked in but not when mowing as in making tight turns. As Brian mention about churning the ground, that may be somewhat similar as when I make a tight turn in my pickup when the front wheels are locked which seems to make it bind. When not on pavement I sometimes forget to take the truck out of 4X4 but when I make a tight turn it gets my attention. Danny
KMC 7406 (A64126)
KMC 7406 (A64126)
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
Woods Brushbull 60 3Pt Mower (A66285)
Woods Brushbull 60...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
2006 John Deere 5425 (A64126)
2006 John Deere...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
