4 Wheel Drive
   / 4 Wheel Drive #1
BeeFarmer
S.E. Ohio
TC 33D
I've noticed that when I am in mud that when I place my TC33 into 4 wheel drive that both the front tires don't spin or when pushing something one tire will spin and the other doesn't seem to kick in. When putting the unit into 4 wheel drive I push the clutch in and put the handle foreword. I don't notice any clicks or anything really different when I push the handle foreword and then let the clutch out. Just doesn't seem like anything happens. Is there any settings or test to see if the 4 wheeling is working as it is suppose to be?
Thanks
   / 4 Wheel Drive #2
If you are spinning 1 front tire the 4WD is working. There is a differential in the front just like the rear that normally only power is applied to the tire with the least resistance. In the rear you have the diff lock that will lock both tires together, unfortunately the front doesn't have that. /forums/images/graemlins/frown.gif 4WD is really incorrect. More correctly it is true 2WD. In a typcial 2WD truck you are lucky if one rear tire will pull. 4WD gets you one front and one rear - Unless you have lockers like on the rear of your tractor. The rock crawling trucks and stuff that you see will typically run air lockers in the front and rear to give them true 4wd. In a true 4wd system you will find that it is very difficult - if not impossible to turn - and VERY, VERY easy to break something. Hope this helps. /forums/images/graemlins/smile.gif
   / 4 Wheel Drive #3
I'm probably missing something here . But that seems normal to me . On the front you have what is called an open differential . The wheel with the least traction will spin .
For the most part the rear diff is the same (unless you lock it with the pedal ) . If both front and ,or rear diffs. were locking types ,you would have great traction in a straight line . But you'd really suffer when turning . Anywaythats my take on it .
all the best , John
EDIT ... Jim beat me to the keyboard .... My fingers must be getting old /forums/images/graemlins/smile.gif_
   / 4 Wheel Drive #4
Hey, at least we were consistent and said the exact same thing. /forums/images/graemlins/grin.gif That doesn't happen very often. /forums/images/graemlins/smile.gif
   / 4 Wheel Drive #5
That's a scarey thought /forums/images/graemlins/smile.gif John
   / 4 Wheel Drive #6
I'm not sure about this, but if you've got a DA, seems like I remember the 29/33 size having a "traction" control where the power is transferred to those tires not spinning...could be wrong, but I was on a 29DA recently and I seem to remember the salesman saying something about that???
   / 4 Wheel Drive #7
<font color="blue">...seems like I remember the 29/33 size having a "traction" control where the power is transferred to those tires not spinning </font>
That's the Sensitrak feature that comes with SuperSteer.
   / 4 Wheel Drive
Maybe I should of said I had SS!
   / 4 Wheel Drive #9
I've got Detroit lockers in both ends of my Jeep, steers fine in 4WD. Wonder if they make one for a CUT?
   / 4 Wheel Drive #10
BeeFarmer I am sure that you are aware Sensitrak is a part of your SS option. You should never really need to place the 4WD lever in the lock position as it will take place automatically whenever needed. It's so fast and so smooth that you won't even be aware that the transition is taking place.
I noticed the other day that while grooming my gravel drive I was having a bit of a problem in a sharp turn with the front wheels digging into the gravel and looked over to see that my son had indeed locked my TC-40D in manual 4WD. Since I never use the lever myself I returned it to the automatic position and all was well. In a normal steep turn Sensitrak shuts off the 4WD so that you don't damage the turf or put a bind on the SS drive-train. This all takes place from the normal or automatic position for the 4WD lever.
   / 4 Wheel Drive #11
hmmm! I bet you spoke to your son about playing with your levers. /forums/images/graemlins/grin.gif
   / 4 Wheel Drive #12
My TN75D has electro hydraulic diferential lock that locks both front and rear axles at the flip of a switch. And yes it does make the front end tear up what ever it is on when turning as one tire has to slip. But it does make it upll like a mule. /forums/images/graemlins/cool.gif
Andy
   / 4 Wheel Drive #13
<font color="blue"> hmmm! I bet you spoke to your son about playing with your levers.
</font>
My son is 25 so it really wouldn't do much good telling him what I want. They are pretty independent at that age, and no harm was done either. /forums/images/graemlins/grin.gif
   / 4 Wheel Drive #14
EXACTLY! Thanks for putting the correct term to it. I went back and looked at my literature and found that as well - good job!!
   / 4 Wheel Drive #15
I have a BX-22, But when I learned that NH was making this thing, I just might have to get one. who makes the motor
   / 4 Wheel Drive #17
whats this thing designed to compete with, the JD X-series
or the bx series.
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
International 9200 (A61307)
International 9200...
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2362 (A60432)
2362 (A60432)
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
