4 Wheel drive indicator with inclinometer install on a Grand L Cab
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab
Just to clarify why I wanted the meter installed in my tractor. I have done a lot of grading, 3 large lawns and 2 driveways, so far.
I have 5 properties.
Now I consider myself pretty good at grading spent about 500hrs on my B3030 just grading.
At my house I had to make the ground rain water go around my septic system and I pitched the grade away taken up a large area.
Sometimes its an optical illusion one way it looks like your going up hill, turn around and it still looks like its uphill even though its not.
I thought it would be nice to have one in the cab for this reason.
The meter would be good for if you wanted a driveway with a 5 or 7 or whatever degree grade, and you didn't want to go over that grade while you're working.
Or a nice long 3 % pitch for water to drain etc, or you want to make sure you don't go over a 10 % grade or pitch in any area.
Or you want to level out a nice large flat lawn with topsoil.
That is why I put the meter in my cab.
I do not go 4 wheeling, I do not dangle on the edges of cliffs, or do I try to see what my tipping point is.
A tilt meter on a tractor in my Opinion is a tool used to maintain a grade while grading soil.
Oh you say well that was only his opinion No it was him trying to put down my meter to build his up. The second video proves that without a shadow of a doubt.
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab #82
I am in the process of building my own design tilt-O-meter.
Basically it is a coat hanger, fresh roll of toilet paper (thanks to 4shorts video) with a pointer hanging down over a colored pie chart taped to the windshield so I never take my eyes off it. Still have some thinking to do as to what the pie chart will say, throw me some ideas so it works better.
I'll do my own video testing it on my nasty lawn with the fred mask on.
:stirthepot: Fred :devil: If you thought the turbo video was funny wait until you see this! Gotta find some time in between snowstorms.
1
Video #1
Kubota BX25-D Fuel Filter Conversion - YouTube
Video #2
Rad 1 Digital Inclinometer for the Kubota Grand L 5740 - YouTube
Besides the meter is almost at eye level as it is, your video shows you staring up at Mars or something.
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab #84
I think it looks good.
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab #85
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab #86
Seriously it looks like a factory option. Very nice work!
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab #87
PapaPerk is right--it DOES look like a factory option.
Waxman,
If I may ask, including sourcing the display, how many hours did it take you to design, build, install and test?
And (and this is none of my business, so only if you feel like sharing...) I'm curious as to how much money you have in it (roughly).
And lastly, is there any truth to the rumors that you are directly descended from the Great Nikola Tesla (the TRUE inventor of radio, and approx. 115 other US-patented items, many of which we use today, most without any idea of the debt we owe this great man)?
Amazing work!
My Hoe
Waxman,
Amazing work!
My Hoe
Thanks Hoe,
The used Toyota inclinometer I bought was 60.00 shipped, from Ebay. I saw them sell on Ebay anywhere between 25.00 to well over 300.00 dollars, they sell at the mid to higher range today verses a couple of years ago. It was an expensive option on the Toyotas and still valued highly today. Here is a link to the recent completed ebay auctions.
The meters have been around for 20 years and still going strong today commanding high prices.
Check out these prices.
toyota inclinometer | eBay
You can buy them with an altimeter, clock or the 4 wheel drive light. The actual tilt meter is the same meter on all of them. The one I bought with the 4 wheel light makes it perfect for my tractor. Toyota even has Kubota orange silkscreen writing along the bottom for an even more factory look and the kind I bought does not say Toyota on it which makes it perfect for a Kubota tractor.
If it did say Toyota like some of the others, I would not have used it on my tractor.
I knew I didn't want the custom moulded foam cover so I looked for the cheapest one with the most beat up cover, but with the best display.
When I bought it I had no idea if I was even going to be able to mount it anywhere, the only thing to do was buy it hold it in my hand and see if I could make something with it or not. I figured I could always resell it if it didn't work out.
Time I spent-- a few days? a week? maybe ten, twelve hours if it was steady start to finish. I spent more time figuring how to make it then it took to make it. That was the hardest part.
I had all the materials on hand. So the total cost was around 60.00.
To make it was not as hard as it looks, I made a cardboard pattern first then use aluminum sheet and 1/2 aluminum angle for the corners. I was going to drill and tap and use screws but I didn't want all the screws so I used the greatest epoxy there ever was "Plastic Welder" 20 minutes you can beat it with a hammer. I have been using this stuff for years.
No special welders, No special skills or tools anyone can make it. I enjoyed doing it and I enjoy having the meter in my cab. Time I spent was nothing for me that is what I like doing. Cost was a couple of trips to McDonalds
I made the frame tight and trimmed the lens of the inclinometer with a block of sandpaper to a perfect slide in fit to the frame. The meter sides were slightly rounded to begin with so a little trimming was needed. I wanted no gaps everything had to be even all the way around. Just one nut holds the unit into the frame.
And only two Kubota factory headliner bolts to hold it up tight against the headliner, its very lightweight.
From the picture above I shorten and turned the bracket around to go under the unit. This was so I can I could use the space behind the unit for switches.
I made a little jig so I knew exactly where to epoxy the bracket.
Testing and use - Whenever I'm on a hill I check the meter to see if its 10 degrees or less side to side then I know It's OK.
Love the 4 wheel drive light, I know in an instant whether its in or out of 4W.
As for testing - this picture below with my IPhone shows its close enough, looks about 8 degrees to me and in two wheel drive according to the meter.
As I said in the fist post of the thread I looked all over for a compact digital one but they just don't make them today, they turned out to be hard to use and unreliable, they got very bad reviews so they're off the market now.
Innovate Motorsports' RAD-1 Digital Inclinometer - 4x4Review Off Road Magazine
I decided to go this route instead.
Toyota is old school mechanical, trusted accurate with the use of gears and gravity, Not springs, And if anyone is wondering, it has damping action in the meters, because of the gearing they turn slow and super smooth, not bouncing all around so you can't read it. Not like the other mechanical ball and tube which is also very accurate but the ball is always swinging. Same can't be said about the one digital that was tried, failed and discontinued. These Toyota meters are made with high quality Japanese movements, that is why they are still around and in demand even today.
It's a funny thing about mechanics and gravity, these brass weights attached to the gears shown below always end up on the bottom no matter what way you hold it. Nothing to fail.
I have it mounted in a spot where I don't have to look away to use it and doesn't interfere with my line of site or the defrosting of the windshield one bit. Never has my windshield fogged up at any time thru two hard winters now. Its in a perfect spot up out of the way but easy to view.
The factory look is what I was aiming for. Thank you, Hoe, PapaPerk, and 94BULLITT (sorry I just refer to you as hoe, but something about calling you My Hoe just doesn't sound right):)
I'm very happy with it and thats what counts. The little time and money spent was well worth it. I wish I had more projects like this one.
Thank You for asking.
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab #89
Waxman you ARE the best!
Fred
   / 4 Wheel drive indicator with inclinometer install on a Grand L Cab #90
10 plus on the cool scale Waxman.
Do have any history on the piece?
Regards and nice work as usual, Fred
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
