4 wheel drive assist lubing
   / 4 wheel drive assist lubing #1
IH3444
I was also reading the manual about lubing the 4wd assist driveshaft. It states in the manual this should be done every 50 hours. It doesn't go on the describe where to lube, what needs to be lubed.....Is it the drive splines?:confused:
   / 4 wheel drive assist lubing #2
I believe most of the 4wd TCs have a zerk right behind the front axle, immediately in front of where the driveshaft connects.
   / 4 wheel drive assist lubing #3
I have two on the axle pivot point, and one on the shaft.
Thanks, I knew about the axle pivot point......but was wondering if I should remove the shields and apply oil lube to the splines. I have seen in the past splines which ran dry and destroyed themselfs.......:eek:
JLG 1255 Telehandler (A53472)
JLG 1255...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2006 FORD F250 SERVICE TRUCK (A53426)
2006 FORD F250...
(1) WHIRLPOOL REFRIGERATOR (A51248)
(1) WHIRLPOOL...
