4 wheel drive assist lubing
   / 4 wheel drive assist lubing #1
IH3444
Veteran Member
I was also reading the manual about lubing the 4wd assist driveshaft. It states in the manual this should be done every 50 hours. It doesn't go on the describe where to lube, what needs to be lubed.....Is it the drive splines?:confused:
   / 4 wheel drive assist lubing #2
I believe most of the 4wd TCs have a zerk right behind the front axle, immediately in front of where the driveshaft connects.
   / 4 wheel drive assist lubing #3
I have two on the axle pivot point, and one on the shaft.
Thanks, I knew about the axle pivot point......but was wondering if I should remove the shields and apply oil lube to the splines. I have seen in the past splines which ran dry and destroyed themselfs.......:eek:
2005 GENIE S-80 MANLIFT (A51246)
2005 GENIE S-80...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
