4 WD PROBLEM
/ 4 WD PROBLEM #1
visioner
PA
JOHN DEERE 4410
I have a 3 1/2 year old John Deere 4410 with about 425 hours on it. I had a oil leak where the front drive shaft comes out of the center housing. It was a oil seal that the drive shaft go through. Behind this is a bearing. the bearing was bad and had to be replaced also. Now whan I flip the switch to take it out of 4wd there is a noise like something is binding than releases. This does not happen when I put in in 4wd. I never heard this noise until now. I don't know of any adjustment. I don't want to any damage to the tractor. Does any body have any suggestion on this problem
/ 4 WD PROBLEM #2
I have a 4610 and all I hear is a clunk. It's done it since day one and even says it's normal in the Operators Manual.
/ 4 WD PROBLEM
I must have missed that part in the manual. What worries me is I never heard it before and it seems loud. Maybe the sound with get less with time. Thanks for the reply
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2009 Kubota RTVX1140 (A64912)
2009 Kubota...
Case-IH P170 6 Cylinder Power Unit (A64912)
Case-IH P170 6...
PORTA POTTY (A67714)
