Loader 4-way valve hook up FEL
   / 4-way valve hook up FEL #1
jam2004
central NJ
Kubota BX 2230
Had to switch from three-way to four-way valve on bx2230 to work snowthrower. I want to attach my FEL but I'm not sure which valves/hoses connect to the corresponding hoses on LA 211 loader. I've seen the new bx's and wish my hook ups were so neat and easy. Can someone help me with this one? Last time I did it, loader would raise, but bucket wouldn't move, then vice-versa. Color coded hoses are not consistent with their coupling mates.
   / 4-way valve hook up FEL #2
If you post a picture of the valve, and trace the lines from the cylinders to identify the lift/lower and dump/curl we can help.
Will do. Thanks.
Massey Fergusson 4710 (A60462)
Massey Fergusson...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
403 (A52706)
403 (A52706)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
