Rotary Cutter 4' Rotary Cutter for EMax 25
/ 4' Rotary Cutter for EMax 25 #1
BigTee
Kentucky
Mahindra eMax 25
I'm looking at buying a 4' rotary cutter for my Mahindra EMax 25. Is there anything special I should be looking for in a cutter? Who makes the best cutters?
/ 4' Rotary Cutter for EMax 25 #2
I had a 4' King Kutter rotary cutter and it was indestructible. Sold it when I bought a larger tractor.
Of all the implements KK makes they enjoy the best reputations for their rotary cutters and roto-tillers.
WHAT DO YOU INTEND TO CUT??
/ 4' Rotary Cutter for EMax 25 #3
Ask 5 people who makes the best BH and it's possible you will get 5 different answers. The usual suspects are Bush Hog, Woods, Landpride, and a few others. I used to have a 15-48 Landpride 4ft bush hog and thought it was a well made medium duty mower. Got great service out of it, until I sold it with a JD 750 I had previous to the JD 790 I have now.
Are you planning to bush hog fields and pastures? Or, are you planning to cut the rough stuff in the woods? That would make a difference. If the former, all you really need is a standard light duty mower with a 45hp gear box. If the latter, then get one with a heavy duty rating, larger gear box, and thicker steel on the deck.
Just look at all your available options closely and see what you think fits your budget and your needs the best. Good luck.
/ 4' Rotary Cutter for EMax 25 #4
Sorry to infringe on the thread...but I too have been shopping for a 4' rotary cutter...due to my ignorance on the topic I recently discovered that smaller cutters are available...
Any opinions on this cutter...the asking price is $500....anyone know what they sell for new?
I'm going to be cutting some nasty stuff. It's about 10 acres of pasture that hasn't been touched in about 20 years. I'll have to do some chainsaw work to get it where it can be mowed.
/ 4' Rotary Cutter for EMax 25 #6
If you can get that mower for $500 (or less), then I say JUMP ON IT before someone else does. It looks almost new (and medium duty too), and you would probably be getting it for half price, or even less than half the price of a new unit just like it.
I just sold a 5ft Ro-Cut light duty bush hog mower (made by Taylor-Pittsburgh) yesterday for $500 and it wasn't near as nice as that one is.
I'm sorry that I thought you could probably guess what an untouched pasture would look like after so many years, small trees, briars and a lot of weeds. And I'm also sorry that I asked some knowledge to be shared. It seems that if you are not an articulate writer that you don't deserve task for some guidance. I'm sorry that I asked for the advise.
/ 4' Rotary Cutter for EMax 25 #9
I don't know. That looks like a well-used cutter that has a fresh coat of paint. Look at the tailwheel. It's got paint on it. It also looks like the support frame for the tailwheel got a half-azzed paint job.
To the OP, I'd check that cutter out carefully. Check the gearbox for oil. Check the blade pan / blade carrier underneath it to see if it has oil on it, which is a sign of a leaking seal. See what condition the blades and underside of the deck are in. It could be a good buy, or it could be a problem child with a fresh coat of paint.
/ 4' Rotary Cutter for EMax 25 #10
Of all the implements KK make they enjoy the best reputations for their rotary cutters and roto-tillers.
I pulled the KK 48" behind a Kubota B-series with 25-hp PTO. It cut 1-1/2" saplings without strain. May have cut 2" stuff going slow, but for the larger size stuff I ripped it out roots and all with a Ratchet Rake on the bucket.
Photos: B3300SU 33hp/25hp PTO.
/ 4' Rotary Cutter for EMax 25 #11
You are in Kentucky, somewhere. I am in Fanning Springs, Florida. I have little idea what an untouched pasture in Kentucky would look like after 20 years. Your weather is different, your seasons are different, your soil is different, your vegetation is different.
Some cutters are built just for light duty, some medium duty, which can cut 2" routinely, then there are heavy and super heavy cutters that can cut 4" - 6" with enough power applied. Priced accordingly. Some brands more-or-less specialize in one part of that market. I am trying to steer you toward a cutter adequate for your needs without overspending…...
/ 4' Rotary Cutter for EMax 25 #12
If it runs without squealing and the blades seem o.k., it's a good price by Ontario standards where a new one runs $1400. plus tax. Be sure to have the owner spin it up and demonstrate its cut.
2007 FORD FREESTYLE SEL (A60430)
2007 FORD...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2019 CATERPILLAR...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
