4 point backhoe B2650 ????
/ 4 point backhoe B2650 ???? #11
I'm not sure how your 2650 compares in size to my 3300 but I love my BH77. The 2650 is a bit smaller frame no?
I'm lucky to break thru 4" of frost with mine but soil types will have a lot to do with that. The single seat setup is WAY nicer in my mind than the dual setup of some other brands. As Tompet said, you can reach up to the tractor controls (key, throttle, steering, bucket) much easier than on a dual seat. Similarly, from facing forward, you can reach back to the BH controls if you need to.
As far as spinning the seat around or using a stick on the HST pedal to move the machine to continue digging, those are the two WORST ways to do it. Watch a pro for 5 min and you will quickly realize there is a better way to do it:
Put trans in Neutral after initial positioning.
Dig what you can until you need to move.
Crowd both the boom and stick and put the bucket on the ground.
Steer as needed by reaching around behind you to the wheel.
Lift the stabilizers a bit and lift the FEL.
Push away from you with the BH moving the whole machine forward.
Put FEL and stabilizers back down and resume digging.
Repeat.
You should be able to move exactly the right amount to dig as much as you can in every move. You will quickly realize how much more productive it is this way, even when you aren't on the clock for someone. I've done a 150 ft hydro trench and a 100 ft drainage tile around trees & corners and stripped sod off an irregular area of roughly 50x70 with never leaving the BH controls. Forward, backwards, sideways, it's all possible by using the BH
/ 4 point backhoe B2650 ???? #12
The reason I'd like the separate seat model is I wouldn't have a huge amount of hours to put on a BH, definitely more so in forward facing work. I'd rather not lose the nicer suspension seat for the more solid mount. It's handy to swivel, dad has it on his BX, but this seat is such an upgrade in my opinion for loader work that I'd rather not lose it.
/ 4 point backhoe B2650 ???? #13
Now I hadn't thought about having a nicer front seat as a possiblity with dual seats. When I was shopping, all of the 3300s at my dealer already had a BH mounted so it never even occurred to me. Isn't the 2650 more of a deluxe model to begin with which would get you that nicer seat?
/ 4 point backhoe B2650 ???? #14
Ya the 2650 and 3350 have the suspension seat, but that get's removed as I understand when you get the BH. Unless of course if you're allowed to get the cab model BH instead. I don't think the other B's have the suspension seat.
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2004 John Deere 4720 (A60462)
2004 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sdlanch SDLGC80 (A60463)
Sdlanch SDLGC80...
FUEL CELL (A58214)
FUEL CELL (A58214)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
