4 in1 loader is great
/ 4 in1 loader is great #1
Hillbilly
Platinum Member
Finally bought a JD loader for my JD 4400,while I was at it I decided to go with the 4 in 1 loader.I had people tell me the loader was the most handy thing on there tractor,well I would have to agree now,but I would also have to say the 4 in 1 bucket makes my loader even that much more useful,amazing the uses I have found
with a loader,a back saver and time saver.
I have used the loader to lift numerous T - posts out of the ground,I have grappled several logs 12" to 15" in diameter and 12' to 15' long and stacked them.Yesterday I removed part of an old electric pole out of the ground.The pole had been set 18 years ago and a couple of years ago it was cut of at ground level.I took the loader and scraped a little bit of dirt from around the pole and opened the 4 in 1 an wiggled the post around and lifted it up out of the ground, about 3' long and then went back an pulled the old ground rod up as well.Tree tops across a road in the woods,I opened the loader up and pulled the top out of the road and carried where I wanted to drop it and opened the loader and let it fall.Great investment for me.
/ 4 in1 loader is great #2
Hillbilly, that’s a great addition to your tractor, congratulations on the new loader. How are the controls set up for your 4 in 1? Sounds like some have an extra lever and some a button to activate the jaws.
I think it was MarkC that used his to trim low branches from trees on his trails. Always thought that sounded like an unexpected use.
MarkV
/ 4 in1 loader is great #3
HIllbilly could i ask how mutch it was i had a bear of a time removing grounding rods had too dig most of it out also dropped abunch of trees and need help cleanig them up is the 4 way hard too learn to operate? and what size bucket is it
thanks edt
/ 4 in1 loader is great #4
Hillbilly:
Congratulations on the addition. I agree with you on the utility of the 4-in-1 bucket. I just bought a Ford 1520 that had a 4-in-1 bucket on it. I had a lot of railroad ties that the previous owner had used for landscaping, that I had to move to do work on my driveway and some clearing for pasture. The 4-in-1 bucket just allowed me to pick them up and take them wherever I wanted them. I could even stack them neatly. A real back saver. I have also used it to clear downed trees from trails and the dozer capability with the bucket wide open has been usefull for moving dirt and manure piles. I don't think I will have another tractor without the 4-in-1.
Men,
The 4 in 1 bucket cost around $5500 installed of course.Sounds a little high...but I did not have any SCV's at all connections etc..this all had to be installed.It was a little steep.My dealer is on the high side,but I always get good service and all the good dealers are 30 to 50 miles away.
The bucket is 5' wide(430 loader).
It is easy to operate...2 levers....one to raise/lower and curl the bucket...and another lever located on top the right fender to open and close the bucket....it is easy a heck to use and operate....they talk about these JD loaders being so easy to disconnect and reconnect....heck I could not tell you one way or another...I have not had a reason to take it off and I cannot see me ever wanting to take it off/w3tcompact/icons/laugh.gifalthough I am sure sometime it will need to come off.
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
1989 Freightliner FC60 Day Cab Truck, VIN # 1FUP2DYBXKH356541 (A65563)
1989 Freightliner...
2021 International HX620 Quint Dump (A62613)
2021 International...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
