4-in-1 vs. Std. Loader
/ 4-in-1 vs. Std. Loader #1
DAP
From Orange County NY to Lincoln County ME
JD LX288 and a B7800
I notice that there isn't that much on the board in general (of course I've found some) in discussion of 4 in 1 buckets. I know that they are:
1. More expensive than std. loaders.
2. A lot heavier requiring some rear ballast
... but without having actually used one, they seem to me to be much more useful. Can the 4-1 owners chime in here? Any opposition to the 4-1s?
Do they hold a lot less general than their counterpart loaders?
Grabbing, pulling, scraping, top-down loading ... seems to be the thing to me. But I'm still a 4-1 novice .. so let's hear your thoughts.
/ 4-in-1 vs. Std. Loader #2
DAP--- I know you are looking for 4-1 owners which I am not /w3tcompact/icons/frown.gifbut I sure would like to be. I’ve looked into it and figure that for my B21 the cost would run $1500 to $2000 after all the hydraulics and setup. The issue that slows me down is the extra weight. With smaller loaders the 4-1 will lose you about 200 lbs of capability. That is to much loss for the way I use my tractor. When I go to a larger tractor it will be on the top of my list.
Steve Carver has some good information about 4-1 systems on his site. You might want to take a look there.
MarkV
Hi Mark, I've read the Carter notes on 4-in-1s. I'm looking to put this on a B2710 or B2910. Althought a lil larger than the B21, you may still make your point regarding weight and capacity.
Hopefully others will chime in and reply. It would be an expensive mistake methinks!
/ 4-in-1 vs. Std. Loader #4
I have a B21 with a 4 in 1 and consider it one of the most important tools I have.
It cost alittle more, but then so does everything worth having.
It adds weight thus lowers your lift capacity - So I may need to take a few more scoops per job. I can rarely fill it anyway...
But nothing makes up for wearing virtual gloves instead of mittens
2015 Volvo L110H Articulated Wheel Loader (A64553)
2015 Volvo L110H...
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
