4-in-1 4-in-1 Bucket practicality, opinions vs. separate implements
   / 4-in-1 Bucket practicality, opinions vs. separate implements #11
Biggest thing I don't like about them is, they are HEAVY, and on small tractors that don't lift that much in the first place, it cuts that down even more.
IF you have a bigger tractor and get one that "isn't" heavy, it won't last long...
SR
   / 4-in-1 Bucket practicality, opinions vs. separate implements #12
They are junk if you grade a lot with front bucket. Terrible to grade with.... The only good thing about them is you pick the last little bit up of a pile....That’s it. You can pick the last little bit up without a 4 in 1 with a little practice.
   / 4-in-1 Bucket practicality, opinions vs. separate implements #13
If you get it, you will like it. But then you will soon be disappointed with your lift capacity and the want for a bigger tractor will set in. A tooth bar for digging and a box blade for scraping will go a long way. I started with a grapple on a 2520 and then moved to a 3320 a year later for lift capacity. I kept the 3320 for 12 years but still wished for a 4 series. Tractors can get expensive.
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
72'' SKID STEER BUCKET (A56857)
72'' SKID STEER...
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A58017)
2007 INTERNATIONAL...
