4-in-1 4-in-1 Bucket practicality, opinions vs. separate implements
   / 4-in-1 Bucket practicality, opinions vs. separate implements #11
Biggest thing I don't like about them is, they are HEAVY, and on small tractors that don't lift that much in the first place, it cuts that down even more.
IF you have a bigger tractor and get one that "isn't" heavy, it won't last long...
SR
   / 4-in-1 Bucket practicality, opinions vs. separate implements #12
They are junk if you grade a lot with front bucket. Terrible to grade with.... The only good thing about them is you pick the last little bit up of a pile....That’s it. You can pick the last little bit up without a 4 in 1 with a little practice.
   / 4-in-1 Bucket practicality, opinions vs. separate implements #13
If you get it, you will like it. But then you will soon be disappointed with your lift capacity and the want for a bigger tractor will set in. A tooth bar for digging and a box blade for scraping will go a long way. I started with a grapple on a 2520 and then moved to a 3320 a year later for lift capacity. I kept the 3320 for 12 years but still wished for a 4 series. Tractors can get expensive.
2007 Western Star 4900 Semi (A59814)
2007 Western Star...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Case DX25E Utility Tractor (A59814)
Case DX25E Utility...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
