4/0 Copper Battery Terminals Found
/ 4/0 Copper Battery Terminals Found #1
TractorGuy
Elite Member
N. FL
John Deere 4410, John Deere 4120, Kubota LX3310 cab, John Deere F725 Front Mount Mower, Swisher 60" pull behind mower. John Deere 4310 CUT (sold), Ford New Holland 575E Cab Backhoe (sold).
Recently purchased a used backhoe that had those awful emergency battery cable ends on it. I know it's best to replace the whole cable but these cleaned up and looked decent except the original ends were gone. Could not find any 4/0 solder on ends local but found them HERE on the net. Nice that they actually had them in positive and negative also instead of universal. Got them in a few days and they fit the battery terminals and cable perfect. Just supported the cables in a straight out position, heated the terminals with a propane torch, and fed 40-60 rosin core solder in till they filled up. I didn't think to order any large heat shrink so I taped off the cable side with electrical tape. Machine fires right up!
/ 4/0 Copper Battery Terminals Found #2
Soldering will work, but crimping battery cable connectors is much better.
The solder does not go only into the connector, but it migrates along the copper stranded cable as well.
This creates a cable that is not flexible near the end.
/ 4/0 Copper Battery Terminals Found #3
I made a little melting pot for solder . 1" pipe 2" tall on a piece of 1/4'' 4x4 flat with a handle . Melt a little silver solder , dip the ends of the cable and let it sweat in . Then crimp . Just me .
Yeah, Yeah, everyone has a better way. The material on these was so hard a drill would not cut it so I was afraid they may crack if I tried to crimp. They do list them as crimp or solder. I gave em a good tug after cooling and could not pull them off.
The point of the thread was linking a source for correct ends. I could not find any local.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
1996 Chevrolet Astro Cargo Van (A64194)
1996 Chevrolet...
Woods Cadet MD172 Pull Type Mower (A66408)
Woods Cadet MD172...
