3rd function solenoid plumbing
/ 3rd function solenoid plumbing #1
ktm250rider
Finally got my electrical work done for my solenoid valve. Just need to neaten up the wiring and figure some way to mount my switch besides using zipties. So, I fire up the tractor and after quickly finding some loose fittings my bucket curl doesnt work. I can hear the solenoids switching. I attached the solenoid that I bought below. I noticed that on mine the inlets show P1 and P2 rather than VE and VR.
I have my yellow, rod end cylinder (port 1) coming from the tractor hooked to P1 and the Red, port 2 to P2. I then connected the lines from port 1 on the solenoid to the bucket cylinders.
Any idea whats wrong?
https://www.surpluscenter.com/item.asp?UID=2009102415582650&item=9-5117
/ 3rd function solenoid plumbing #2
Have you checked for voltage at the coils? You do have a SPDT switch correct?
This valve must be powered all the time...
I believe its a SPDT switch. Its always centered, push one way and release it returns to center, likewise with opposite direction. I cant find any decent markings on it, and I dont have the packaging.
No constant power when switch is activated.
looks like i need a different switch. If i hold the switch in one postion, everything works fine. Once I release it, power goes away and solenoid must be closing.
/ 3rd function solenoid plumbing #5
Agree. look carefully at the wiring diagram...one solenoid ALWAYS need power. No power and all ports are closed. And you do not need a center OFF switch either... A ON-(ON) switch would work well here, where the one ON position is momentary.
If you look at the 9-5117-A valve, they corrected the "problem" of having to energize one coil all the time...
2008 Generac SD100 T3 125kVA Standby Diesel Generator (A66734)
2008 Generac SD100...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2018 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A65057)
2018 CHEVROLET...
HYDRAULIC MANIFOLD SKID (A68842)
HYDRAULIC MANIFOLD...
Unused 2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
Unused 2023 USA...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
