3rd Function Options
/ 3rd Function Options #1
THEPARTYHOUND
Montana
JD 2240 MFWA (SOLD); Kioti RX7320
Hey fellas, what options does a guy have for a 3rd Function on an RX7320?
/ 3rd Function Options #2
If it's like my NX, there's a factory option that's decent. Cost is comparable to aftermarket products. The instructions that came with it were terrible though. Small pictures, diagrams that showed "Use part 17 here" when part 17 had a sticker on it labeled as "A" or "B"...stupid stuff like that. I did a lot of looking or squinting at the pictures. Took me about 5 hours to install, taking longish breaks because it was hot outside. Part of the factory option requires the removal of the loader control stick and replacing it with a new one with buttons. Pretty nice...but you have to overcome the red loctite they used on the original loader control stick first. That alone took me about 45 minutes to replace. Also, it helps if you remove the loader first to give you some clearance to add the support bracket for the hoses going up front. It was next to impossible, even with a set of service wrenches, to get to the hydraulic fittings.
ATS Mini Excavator (A66408)
ATS Mini Excavator...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
Kuhn FC400RG (A60462)
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
Rhino HPHD (A64127)
Rhino HPHD (A64127)
1987 INTERNATIONAL S1900 S/A BOX DUMP TRUCK (A64277)
1987 INTERNATIONAL...
