3rd function coupler size?
/ 3rd function coupler size? #1
swhall65
John deere/ 4052r
What size couplers come with the 3rd function valve kit on a 4052r with a 440r msl loader?
/ 3rd function coupler size? #2
I just bought two male couplers JD part # AM105467 ($16.78) to couple with my 3rd SCV kit on my 4300. Would suspect yours would be the same.. This has the o-ring with 3/8 npt female.
Have added a thumb to my FEL forks and ran lines back to the rear 3rd SCV.
/ 3rd function coupler size? #3
The part number you referenced is a 3/8" coupler. NPT do not use O-rings. It is an ORB fitting, size SAE 8 with 3/4-16 threads.
/ 3rd function coupler size? #4
Z
That is correct.. my bad. No o-ring.
The 3rd function kit is blv10764. The parts list with kit shows 2 couplers part #lva13231. I'm assuming these are the couplers that grapple will connect to. I'm going to order grapple from everythingattachments and need to know which couplers I need.
/ 3rd function coupler size? #6
I have a 440R FEL, and have a grapple from everything attachments with the wrong couplers. The number on the FEL third function coupler is NV14-38 SAE F.
amazon.com/Faster-Coupling-NV-14-38SAE-Agricultural/dp/B01MEEM5VM
