3rd function control on the Joystick
   / 3rd function control on the Joystick #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I am wanting to add a grapple for my loader. But I can't seem to find a control setup that looks like this use was considered. On Deere stuff, the options from JD include a 3rd scv with the control set to the right of the seat. Or a diverter, with it's switch in about the same spot.
To operate the third function, you'd take your hand off the sdtick to close the grapple. But if you need to shift the bucket or boom, you'd have to go back to the stick.
With the diverter, you get to operate the grapple using the stick, but once again you can't move the bucket without toggling back.
Some diverters put the switch on the stick, that is better, but not perfect.
Perfect is a 3rd scv control mounted directly to the joystick, allowing operation of all three spools simultaneously.
Can that be done?
   / 3rd function control on the Joystick #2
I'm not quite sure I understand what you are wanting? I installed a Fasse valve (diverter) with a momentary switch on my joystick. I only have to hold the button down to activate the grapple- my hand never leaves the joystick. Here is the thread- Diverter Valve- Momentary switch
Not sure if this is what you were asking, but maybe it will help someone /forums/images/graemlins/smile.gif
Jason
   / 3rd function control on the Joystick #3
</font><font color="blue" class="small">(
Can that be done? )</font>
The kit from WR Long does exactly that, it is electrically operated spool valve, NOT a diverter.
   / 3rd function control on the Joystick #4
Ok- I am confused... I still don't see how you could do things simultaneously when you have to push a button to select one or the other?? How can one joystick control three functions?
Jason
   / 3rd function control on the Joystick #5
Jason, We have diverters on our FEL's so you can only do one function at a time. I know quite well that you understand how they work...
The kit from WR Long actually taps into the PowerBeyond circuit. It is not a diverter, but a solenoid operated spool valve. You cannot "feather" the flow...it is ON or OFF, the switch is a momentary 3 position rocker. So you can theoretically operate lift, curl, and grapple at the same time.
Now the real question is do we have enough hydraulic flow (GPM) on our CUT's to actually operate 3 functions at once...I say no so I think the diverter is the better option for a FEL remote. And the plumbing is simpler also...
Does that help? Or should I explian it a different way?
BTW...Congrats on the new backhoe /forums/images/graemlins/shocked.gif I am jealous...
   / 3rd function control on the Joystick #6
I have never seen a commercially available joystick whose linkage controlled three spools. There may be some custom design out there but they are one of a kind for a specific application.
I have the WR Long electric/hydraulic kit for my grapple and its just a seperate single spool solenoid valve. It's not a diverter so you get a real third function with the flick of a rocker switch. Its MSRP is just a little over $500 but includes all hoses fittings and the handle.
   / 3rd function control on the Joystick #7
Here's my Fasse setup, you cant use all the functions "simultaneously", but it works so well it seems like they do.
My Fasse Setup
   / 3rd function control on the Joystick #8
That is one nice setup you have there for the Fasse valve. And the joystick looks like it came right out of a F-18 Hornet. Cool /forums/images/graemlins/cool.gif
   / 3rd function control on the Joystick #9
KennyD-
I do understand the difference between the diverter and a solenoid operated spool valve. I don't see, however how you could do three things at once with one joystick when to operate one valve a switch must be activated. I think I understand the differences in the setups, I just don't see how they would act different than our diverters?
Jason
   / 3rd function control on the Joystick #10
Maybe I get it now!
I reread the info from Wrlong. Does the rocker switch actually operate a function without moving the joystick? If so, that would be the difference
Jason
2010 Chevrolet Silverado (A47384)
2010 Chevrolet...
John Deere 724J (A47384)
John Deere 724J...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
Case IH 2388 Combine (A50514)
Case IH 2388...
2015 Ford F-150 4x4 Pickup Truck (A50323)
2015 Ford F-150...
