3pt wont engagge
/ 3pt wont engagge #1
Mark4510
Northern California
JD 4510, GT 275
I seemed to have forgotten that I did not park my tractor inside and did not cover it. As a result it had a week outside where it rained a couple of days.
Now when I click the switch to engage the 3pt it does work. The little light on the right hand side lights up but it does not engage. I can still use the bucket but no luck with the Top N Tilt. I suspect its the electronic switch but can some of the experts chime in here with what the problem is likely to be and the most likely fix?
Thanks folks.
Mark
/ 3pt wont engagge #2
</font><font color="blue" class="small">( Now when I click the switch to engage the 3pt it does work. The little light on the right hand side lights up but it does not engage. )</font>
Uh, you click a switch to "enguage" the 3pt? I don't know what that means. Why would your 3pt be disengaged?
Do you mean the PTO?
Cliff
/ 3pt wont engagge
I am not saying that correctly. To use the Top N Tilt I push a button that disengages the loader. When I push that button and move the lever it no longer engages Top N Tilt and only works with the Loader.
the light on the button still works so I assume I am getting power to that switch but I no longer hear the "Click" down in the rear of the tractor that signaled the Top N Tilt was engaged.
Does that make sense?
Thanks,
Mark
/ 3pt wont engagge #4
Now that makes alot of sense!
What you have is a electric diverter kit to switch the hydraulics from the front to the rear, it is a big solenoid.
You need to see if you have power the the diverter block when the switch is ON. My bet is that there is a loose or corroded wire somewhere near or at the diverter.
Do you have a VOM or a 12v Test light?
/ 3pt wont engagge
Right you are!
I finally crawled underneath the tractor and followed ALL the wires. Just as you suspected there was a coupler that had come loose. Once I plugged the two ends back together it worked like a charm.
I did not see it the first time because it rests on top of the "Diverter" box and I assumed it was plugged in. When I tugged on one of the wires the whole bundle pulled off the top of th box and I found it.
Thanks!
Mark
Hedge Posts (A65640)
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
2009 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2009 MAC 35ft...
2000 Ford F-350 Pickup Truck, VIN # 1FTSX30F3YEB26863 (A65563)
2000 Ford F-350...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
