3PT. weight limits
   / 3PT. weight limits #1
randy1687
I have a little kubota b7510 at my farm. I think the front end loader has around a 400 lb. limit, it is a 272 I think, but what about the 3 point lift?,. My box blade, cultivator, brush hog weight around 400-500lb. each, but what is the limit?. And is there a safety valve that would prevent you from blowing the seals?. New to tractors and could use some advise.
   / 3PT. weight limits #2
FWIW, the Kubota specs list 3 pt hitch capacity for the hydro version of the B7510 at 615 pounds at lift point and 480 pounds at 24 inches behind lift point. I run a woods GB60 box blade that weighs 495 pounds on my B7610 (which has the same lift capacity as B7510) and I have not had any issues to date.
   / 3PT. weight limits #3
Pretty much every hydraulic control valve has a relief built in to prevent damage to the pump and seals, etc. This includes the 3ph control.
   / 3PT. weight limits #4
I wouldn't count on -every- hyd valve having a relief.. but depending on how it taps the tractor system, the tractor system may still have a relief in line.
Dang.. those are some low lift numbers.. how much does that tractor weigh?
soundguy
   / 3PT. weight limits #5
That can't be right. My little tc 21d is some 1200 lbs. rear lift.
Brad
   / 3PT. weight limits #6
Find your manual or order one. The exact numbers for your rig are in there. It also some other useful stuff.
   / 3PT. weight limits #7
I agree.. they look real low. At those #'s.. i don't see how it can use most standard 3p implements. My little yanmar 1700 totes a 30" dirt scoop, and I know it must weight at least 200#.. maybee 225#.. I can lift it filled with dirt.. heaped over.. and I'm guessing total weight is nearing 750+ #.. all I need is front weight.. lift don't even groan at all.. yanks the scoop right up.. and that is a little ~19hp tractor
soundguy
   / 3PT. weight limits #9
Well.. that certaintly changes everything..
soundguy
   / 3PT. weight limits #10
My B7500 3 pt capacity was 1100# if my memory serves, it been a few years since i sold it.
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
WORKSAVER RMB-325-PW LOT IDENTIFIER 105 (A53084)
WORKSAVER...
1065 (A53342)
1065 (A53342)
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
