3pt Sway?
/ 3pt Sway? #1
Dobber30052
Loganville, GA
YM 2210 & Farmall "B"
TD, I'm going to take your "Box Blade Sway" question a little further - does the sway distance make a difference as to the implement? Since I'm asking, if there should be a difference in implements how about for a tiller, a rfm, and soon to be box blade, and likely an aerator. I'm sure others would be interested in brush hogs, scrape blades, etc.
Thanks folx!
Dob
/ 3pt Sway? #2
Dobber30052,
The only implement that this has happened to me on is the box blade. In fact, I was out mowing with my new RFM (First Choice) and it didn't happen either. Mower is terrific.
What I've decided, after adjusting the check chains almost as far as they can go, is that the box blade hookups for the lower arms provide quite a bit of room for movement and I think this is really the problem. So I think I will try and get some spacers and put them in the place where the slack currently exists. /w3tcompact/icons/clever.gif
/ 3pt Sway? #3
Every implement is probably going to be different depending on the spacing of the lower lift arm pins. I read where 26" is standard for cat 1 hitches but some are more and some less. I had to use a spacer on my box scraper pins, and reverse the pins on my pond scoop to point inward in order to adjust out the sway. Rotary cutter worked fine as it was.
/ 3pt Sway? #4
You don't want any more play in the sway chains then necessary for raising & lowering of the 3pt. Each implement will be a little different, and the amount of play in each implement will change over time as wear occurs. Any excessive play allows high stresses to occur as the weight of the implement is slammed from side to side. That's what beaks pivot pins and cracks mounting bosses. I make it a point to check each implement after hookup by raising the implement and physically moving it from side to side, adjusting the turnbuckles if it appears too loose. I do have to be careful not to adjust them too tight, or they will bind up when the implement is lowered.
Dave Perry
/ 3pt Sway?
Thanks guys, as usual, /w3tcompact/icons/clever.gif, do what it kinda makes sense. I have likely had way too much play, especially with the tiller, probably 6-8 inches. My thinking was to leave it a little loose for the any buried nasties, so it would jump - I have hit some pretty big stuff, and the racket and bouncing gives me time to raise it. But, I will try a bit tighter, but not too much, Dave!
/ 3pt Sway? #6
Dobber30052,
I could be wrong here since I haven't actually used my tiller yet but don't they normally leave more room for side to side adjustment on tillers in order to provide that "offset"? Don't know but am curious./w3tcompact/icons/hmm.gif
/ 3pt Sway? #7
normde2001,
What do you use for a spacer? I know I need something for this purpose as well.
/ 3pt Sway? #8
Just a plain old 1" hose clamp works great. Was looking for a pice of pipe or something to cut a 1/2" piece from and came upon the hose clamp by accident.
/ 3pt Sway?
TD,
Sounds reasonable to me, and leaving it "loose" did work as intended - My garden only had 1 HUGE rock in it (still need to figure out how to get it out, right now, I know right where it is and just float over it), but, my neighbor across the street asked me to till a patch for him. Good grief, I as soon try to till the road! Inches of dry GA red clay and several basketball sized and larger rocks were found. I have to assume that with no broken tines so far, (knock on wood) that the theory holds. Maybe I would have detected the rocks and been able to lift away, but, becasue the tiller had some room to move side to side, I think helped. Now, let me say, total, I've probably only tilled a whole acre (my 100X100 garden a couple of times, and a couple of patches for neighbors) so, I ain't no authority, but, I am workin on it!
However, I can see where you could break or bend pins and such as Dave mentioned above... so I think I'll do as my father (rip) might have said: Humor it a little in both directions - tighten down a little more, but not as much as for other implements.
BTW, I turned that pile of clay into baby powder, and it sat about 4 inches above the rest of the yard, man, I (and they!!) love that thing! I'm headed down to deer camp this weekend to put in some late season plantings, can't wait! The only thing is I haven't hooked into the FC Box blade yet, so we'll have to drive through the ruts until it comes in!
Dob
/ 3pt Sway? #10
My tractor owner's manual has a chart showing which implements need a looser fit. If you need it I'll email privately.
Turfman
/ 3pt Sway? #11
Dob, talk about Ga. rocks, I dug about 80 of these out of my yard a few miles NW of you. Using them to fill in a ditch I'm putting a culvert in. Dug them out with a crowbar and hammer, rolled them onto the pond scoop, hauled and dumped. The pond scoop seems to be the perfect tool for the job.
/ 3pt Sway?
Yep, Norm, those are the same rocks. I remember seeing that picture in another post, what brand is the scoop? I've been trying to persuade Jim & Pieter to start making them. Seems like the fel market has eaten into the ps market. I found a Kingcutter in AL for $215 (30"). And I like the red...
Dob
/ 3pt Sway? #13
Back home in Fl. now and don't remember name brand. (Not a known brand). Mfg. in Boaz Al., $190 for 24" or 30", purchased from Maynard Equipment, located in Brownsboro and Scottsboro Al.
/ 3pt Sway?
Thanks, I've got Maynard's number(s) and website from when I was shopping for the tractor. I have to go back to AL relatively soon - I have family in Anniston area, and I've borrowed my brother in law's truck & trailer for the planting excursion mentioned above. Maybe I'll swing through and get one.
I'm guessing yours is a Lowery? (Just did a little poking around, and found them). Did you have to do any aftermarket engineering on the scoop? I hear lots of folks talk about them not dumping properly etc.
Dob
/ 3pt Sway? #15
For "sway" allowance in the 3pt, I follow a simple rule.
If I am pushing any attachment (i.e. rear blade, box blade, etc.) backwards, I take out all the sway I can. This keeps the "push" more straight away, and not kitty-wompus. Less likely to damage or break something this way.
If I am pulling a ground-engaging attachment (tiller, plow, disc harrow, sub-soiler, etc.) forwards, I leave plenty of sway, to allow the attachment to find its own path of least resistance, and to let the tractor move around corners with less side pressure applied to the attachment.
Other attachments just depend on how much slop I want to put up with - usually very little.
/ 3pt Sway? #16
Right on both counts, Dob. It is a Lowry, and whoever assembled it obviously did not understand how it operates. The dump latch was torqued down so tight they broke off one of the brackets. Had to take it and get welded locally. ($5), and the bolts that the bucket swings on were also torqued down tight. I made spacers to center the dump latch for smoother operation and greased everything. Hooked up a pully to adjust direction of the dump rope. Touched up all paint, good as new. All in all, still a good deal for $190. I probably would have worked it over anyway, being the self proclaimed world class tinkerer that I am.
2017 Chevrolet Malibu Sedan. (A61574)
2017 Chevrolet...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
UNUSED WOLVERINE PT-16-01C 3 PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
