3pt snowblower recommendation
/ 3pt snowblower recommendation #1
hockeypuck
Lakes Region New Hampshire
Excavator Samsung SE130LCM
I would like to pick your collective brains on what size and make of blower I should mount on the back of my 1533. I have a long drive (1000 ft) but I plow most of it. I would be using it to push back banks and clean up around the yard.
Thanks in advance.
/ 3pt snowblower recommendation #2
I have a Puma (Pronovost) 64 behind my MF1533. I have only had it one season, but so far it has been great. Even on my gravel driveway, I only used 3 shear pins all season. I chose the 64 model primarily because I have a small shed. It covers the wheel tracks with no problem. I was told the 1533 could easily handle the Puma 72. I would recommend the hydraulic chute rotator on whatever blower you choose.
/ 3pt snowblower recommendation #3
I looked at several when buying a few years ago. Loftness blowers work well and are well built. Check them out at the link below. BTW, I'd highly recommend either hydraulic or electric powered chute.
Loftness > Snow Blowers > Tractor Mounted
/ 3pt snowblower recommendation #4
I think I'm going to go with the Allied Buhler. I like the features on the standard unit. Built quite heavy but still under the rating of my TPH. Nice big adjustable skid shoes. List price seems to be just under $1800. Hydraulic chute rotation bracket is $99. I'll do my own cylinders. I think I can add better cylinders for less money than the dealer wants.
/ 3pt snowblower recommendation #5
The make a well built snow blower. Another one that is excellent is Lucknow.
Either way you can't go wrong.
/ 3pt snowblower recommendation #6
I also have a Puma 64". Have used it for 3 years now with good results and no complaints. You just need to carry a lot of spare shear pins, but I think that goes for any blower used on gravel drives.
/ 3pt snowblower recommendation #7
I'm also in the market for a 3PH blower and have been planning to purchase a new Allied/Buhler (both local dealers recommend this brand).
I finally got a chance to see one in person yesterday and was surprised by the design of the skids. They almost look like landing pads where the bottom is dish shaped. I guess I was expecting to see something more like skis.
Is this the common design for these? Do you guys use these or just adjust the top link to control the amount of bite?
My gravel drive is about 1,100' long with 1.5" diameter base rock and 3/4" w/ fines for a top layer.
/ 3pt snowblower recommendation #8
i recommend the woods or schulte brand of snowblower, they are excellent!
/ 3pt snowblower recommendation #9
I have a 5 foot Allied snowblower that I have had for 6 years. I have a 350 feet graval driveway and it works fine. Mine doesn't have the skid shoes but I can controll it with the hydrolics without too much trouble. I have only sheared 1 shear pin in all that time, I have also thrown a few stones into the yard. I live in the snow belt in northwestern PA and have been getting over 100 inches of snow the last few years. Good piece of equipment.
KEN
/ 3pt snowblower recommendation #10
Anyone have any thoughts about 3 or 4 blades on the blower? It's a no cost option the the buhler.
/ 3pt snowblower recommendation #12
Tig said:
Uhm, I meant to say 3 or 4 blades on the fan.
I recently e-mailed Buhler asking what the performance differences are between the 3-blade and a 4-blade. Here is the response I received:
"The only difference between the 3 blade fan and 4 blade fan is the 4 blade fan seems to throw the snow better if it is a wet heavy snow. We have tried both fan types at our location, and we really can not tell the difference, but our conditions might be different then in your location.
We sell most of the 4 blade fan snowblowers in Eastern Canada where the snow is wet and heavy."
BTW, I'm located in Minnesota.
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
Invoices (A65640)
Invoices (A65640)
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
Metal American Flag Sasquatch (A65583)
Metal American...
2011 Ford Expedition SUV (A64557)
2011 Ford...
