3-Point Hitch 3PT Snowblower question
/ 3PT Snowblower question #1
orlo
Platinum Member
Guildhall, VT
JD 2305/JD 4720 cab
Hi:
Some time ago on one of the many thread regarding snowblowers somebody had a link to a
'convertable' rear mount PTO snowblower that could be used going backwards, or used going forward. Basically, the snowblower shell rotated so that the open part was either
in the back or the front. I don't remember what the blower/chute did but it adapted also.
When used going forward you'd have to run over the snow.
Does anyone have this link or know companies that make these? (I searched but I got so many results I couldn't find it).
Thanks,
/ 3PT Snowblower question #2
If its the one i'm thinking of, the lower, auger section didn't rotate...... it had a blade or scoop of sorts that came down and scooped (pulled) snow away from garage doors and such. It was hydraulically operated, and really slick. Of course...... i don't remember which brand it was.
/ 3PT Snowblower question #4
I dont know if you can switch between what way you want the direction to be but Erskine make a pull behind one.
pronovost makes one also.
I know there are others also.
2017 KENWORTH T880 (A67714)
2017 KENWORTH T880...
2017 Dodge Grand Caravan Van (A66738)
2017 Dodge Grand...
PALLET OF HOSE FITTINGS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF HOSE...
2008 FORD CROWN VICTORIA CAR (A66091)
2008 FORD CROWN...
2016 CHEVEROLET CAPRICE POLICE VEHICLE (A66091)
2016 CHEVEROLET...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2018 Kubota...
