3pt snow plow
/ 3pt snow plow #1
fredflintstone
michigan
cub cadet LS4140
not really totally a three point still have the chain but sure could rig something up, Anyhow used a titan
quick attach 3 pt adapter plate, came off plow A frame with some ears, with gussets and welded a solid bar
across both ears for lift arms and a notched peace for the chain turned out pretty good still need to get the
/ 3pt snow plow
yes float the plow just like intended still sticks out a bit but is about a foot shorter im happy with it just see
how it works with the first snow. and im ready for it or not lol don't need to rush it
/ 3pt snow plow #4
May want to run some weight on the back,that cultipacker would work.
I use a 7ft.rear blade also;nice to pull snow away from buildings.
/ 3pt snow plow
you are rite about some weight would like to load the tires but I haul it around a lot
and its already a load. cultipacker would do the trick also chains
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
3" Steel Posts (A66408)
3" Steel Posts...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
1024 (A63111)
1024 (A63111)
2024 CATERPILLAR CP56R PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
