3pt scraper dump
/ 3pt scraper dump #1
marty
Mid West
Boomer 33D
I am looking for something to haul dirt and rock around the yard with and was looking at these 3 pt scraper / dumps that you can use both ways. I just can not justify a FEL at the moment and am looking for options. Does anyone have any advice regarding types to stay away from, features to look for or if I should even consider these?
/ 3pt scraper dump #2
Marty
I have one of those scraper / trip buckets for the 3pt. They are sort of neat tools. Just realize that they take a whole lot longer to do a job than a FEL will & you'll look backward a lot. They don't have any down pressure since they are on the 3pt so if you're trying to dig sometimes you have to set the angle of the bucket pretty steep with your top link. I would suggest at least a hydraulic top link if you can afford that otherwise you spend a fair amount of time adjusting it for different things. The other limitation is that you can't really use them to smooth things out so you have to switch back & forth to a blade pretty regularly. Outside of their limitations they are a pretty cost effective way to move dirt around.
Troy
/ 3pt scraper dump #3
Marty, there is some good discussion about this topic under "dirt scoop" on page 7 of this forum. I too am considering one for the same reason as you.
Mike
2022 EZ-GO ELITE...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
KL480 Ventrac tiller
2018 International HX620 Quint Dump (A62613)
2018 International...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2020 Ford F-150...
