3pt question
/ 3pt question #1
dustin3207
St.stephen MN
Yanmar YM1602D
why does my 3pt not stay in the position I leave it in?
Most of the time I set it to about the height I want. Then I (apply pressure) to the leaver without moving the leaver and hope that it stays.
any thoughts on the problem.
/ 3pt question #2
Don't understand the problem. Can you fill in more info?
/ 3pt question #3
If it won't stay up, then the cylinder probably needs to be rebuilt.
/ 3pt question #4
On my New Holland you set the height you want...... and then can turn the speed control valve "closed" ......... It is located between your feet below the front of the seat and locks the position.
This is what has to be used with the brush hog.
213087 (A64276)
213087 (A64276)
2022 EZ-GO ELITE...
2020 Cushman 1200X Gas Utility Cart (A64553)
2020 Cushman 1200X...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
