3pt planter ???
/ 3pt planter ??? #1
sigpros
Hi guys new here and love the site. i am wanting to build a 2 row planter for sweet corn. What I have is 2 rows and tool bar off an old Allis planter. The untis are like JD 71. It was an 8 row and the guy took a torch and cut 2 rows off. My question is how to make it 3pt? I can weld just can't figure it out. Anyone have any pics? Thanks Chris
/ 3pt planter ??? #2
Morning Chris,
I am in the middle of building a three row planter right now using the JD 71 Flex planters. What I am doing is using a 6x4 tool bar that is 7' long.
I purchaced 3"x4" angle iron and I am cutting the bottom pieces 12" long and drilling them on the 3" side to bolt up to the tool bar using U-Bolts that I had made up. I am drilling the 4" side for the standard lift pins.
I am then taking two of the 3x4's and cutting them at 14 1/2" long, these will be also drilled to accept the u-bolts and then they will be drilled to accept a top link pin. These will have a piece of square tubing in between them welded and drilled to accept a foot post that I can put down to help balance the planter when put down on the ground.
I am cutting and drilling today so when I am done I'll try and post some pictures of the mock up so you get a better idea of what we are doing.
If you search e-bay for corn planters you will see a lot of one and two row planters that might help you, looking at these is what gave me the idea to do mine this way. Hope this helps.
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
Aladdin Hot Gas-powered Pressure Washer (A66408)
Aladdin Hot...
Location Info Please
WORKSAVER 3PT / LOADER BALE SPEAR MOUNT (A64278)
WORKSAVER 3PT /...
