3pt or Stand Alone Splitter
/ 3pt or Stand Alone Splitter #41
Folks - Looking for hands on experience with 3pt splitters
Weighing the benefits of one less engine to maintain, cost comparisons, etc. What experience can you share?
An option I considered is workflow. If I have a standalone splitter - I can cut, chip, and split in series instead of swapping out machines.
Have you found the 3pt which is about the same money as a stand alone to be a better choice?
i was looking at a northern tool 3pt (item# 11965) for $779,but it is no longer available.
The units below range from $950-$1,200 with 16-20 ton psi.
I am running a MF GC2310. My two other attachments are a backhoe and a chipper. My need for splitting is small 1-2 cords a year for the firepit and homestead cleanup (2 1/2 acres).
Thank you in advance for your thoughts.
PJ
I went with the 3pt splitter for the same reason you mentioned. One less engine to maintain. I made a replacement bracket do it attaches up front on my FEL. I learned that it is so much nicer to have my tractor at a nice quiet idle as I split rather then listen to small gas engine screaming away. Have looked at Tractor Supply Company 3pt splitter? It's made by Speeco but it carries the CountyLine name. That's the one I have. SpeeCo Products like it a lot. Just realized that's the splitter in my avatar picture
/ 3pt or Stand Alone Splitter #42
I have a 3pt spliter & have been using it for 20+ years & it's a Northern 25 ton & they don't make this model any more & I'll have to replace the lines on it this year ,which is no problem I can get them made at NAPA ,As You mentioned I was the same way 1 less small engine to maintain! I use it on the older 59 M-F 50 & the flow rate is much slower on a older tractor , But it gets the job done & I've done oak almost 3 feet in circumference easily & without it hanging up But as some others have posted they are a handful to switch in out if you have need for the tractor to do other work & if You decide to go with 3pt splitter go with one that can go horizontal or vertical, I leave mine in the vertical position that way I just roll the wood over to split & I'm not lifting & in 2018 I bought a new tractor a M-F 1526 ,So now I can keep my 50 dedicated to spiting wood & my other tractor for other chores . & I would go the same route again.
(y)
/ 3pt or Stand Alone Splitter #43
Contrary to many I'm 100% in favor of the 3 pt. I've attached castors to the splitters legs and roll it flush up against my garage wall for storage. I split about 2 cords/year and do it all in one day so tying up my tractor is not an issue. I purchased it at Tractor Supply on sale for > $700 and have used it on various tractors from 24 to 35 HP with no issue. The ease of storage, lack of an additional motor to service, and convenience and power of the 3 point attachment cannot be beat IMHO. Quick connect hydraulic couplers makes hookups easy.
/ 3pt or Stand Alone Splitter #44
I have a stand alone 20 ton splitter that pull behind my RTV when needed. I like the convenience of not having to get the tractor out and hook up a 3 point implement... Back the RTV up, drop the hitch, load my gear in the back and head to the wood pile... I use mine several times a year and put Stabil in the fuel, in 20 years never had a problem with it.
/ 3pt or Stand Alone Splitter #45
PJ
I see one of the posts below says your flow is not sufficient for travel speed, so it looks like you have no option, really. But, an issue I did not see really addressed is working height. I have used a home made 3 pt splitter for about 40 years and it still works great. I only bend down to pick up pieces off the ground and lift them to the I beam. Anything too heavy to lift I split in half with a maul or maul and wedge. But I am working at waist height most of the time, wihile doing the actual splitting. And it may be a bit too slow, but only for about the first 5 minutes, then the speed is just right after I get a bit winded.
Those independent splitters are so low to the ground that I could not use one unless I went down on my knees. Granted, I am probably older than you and my knees are shot. But - if you do buy a stand alone splitter, consider modifying it so you can life it with your 3 pt if you want.
Tim
/ 3pt or Stand Alone Splitter #46
They make taller splitters. Mine's got 12" road wheels and it's at a good working height for me at 6' tall.
Rounds that are too large to lift I "noodle" (cut along the grain) with the saw and finish with a splitting maul. Noodling is the fastest cutting direction. It's a lot faster than splitting them just with the maul.
@Syncro - I like the Country Line you show in your pics. I am not sure that TS sells it anymore - didn't see it on their website
@IH2424 - great point on the flow rate. I will have to check my owners manual - pretty sure my GC2310 is 4.1
/ 3pt or Stand Alone Splitter #48
If you don't need the wood for domestic heating , only for a fire pit or clean up cut your rounds shorter why spend money on a 3pl log splitter spend the money on a 4 in 1 bucket that way you can grab and hold your logs or branches at a comfortable safe work height and cut shorter lengths for your fire pit it would be faster as well as less handling not to mention far less stress on your back. you will find a 4 in 1 bucket will be a far better investment with year round uses.
AND pallet forks works even better, especially with a matching grapple!
Plus they cost a lot less and are a lot lighter, meaning you can lift heavier logs.
SR
/ 3pt or Stand Alone Splitter #49
Stand alone. Here are a few pictures of my wood processing set up. Average about 6 face cords per year.
/ 3pt or Stand Alone Splitter #50
Vertical is the way go!Control on 3pt splitter is about 4feet high & once the wood is in place boom that's it f... a maul that's why I got a splitter in the 1st place & I only got bend my knees to pickup split wood, Or reposition a big piece after it's been split (y) & if you wanted to pull up a chair & split wood you could,Until the next piece.:unsure: I meant no offence to anyone , If any was taken.
/ 3pt or Stand Alone Splitter #51
I had to get a new splitter last year and decided on a 3PT simply because I didn't want another small engine to maintain. I ordered a BOSS 22 ton through Lowes. It can go horizontal or vertical and has an auto return on the ram. Website said it came with 1/2" NPT thread hose, but they weren't NPT. I've got it setup so I unplug the FEL and then plug the splitter in. That way the fluid flows freely to the splitter decreasing the heat buildup.
I typically drag the logs to a central area, cut them and then split. If I take the splitter to the tree, then I load directly into the UTV.
On another note, I added a lift and electric winch to lift the rounds up. And I have a second tractor that I use to drag logs with.
But as others have said, your tractor's flow rate will determine if you can use a 3PH hydraulic splitter. Mine has 8 GPM. Not super fast, but fast enough for me.
/ 3pt or Stand Alone Splitter #52
It's just so easy to lift them with the pallet forks over a trailer/wagon/table or ?, and cut them right there,
then move the splitter into position and split right off the trailer deck, easily rolling the bigger ones right onto the splitters beam,
It's much easier, WAAAAAY less handling of splits, and you don't need two tractors ect...
SR
/ 3pt or Stand Alone Splitter #53
PJ
I haven't looked through all of the comments, but they main thing that made the decision for me was something someone posted a few years ago. Running your (expensive) tractor to split logs puts hours on a very expensive tractor motor and hydraulics. If you run a stand alone you are putting hours on an engine that costs a couple of hundred dollars. This made a lot of sense to me as well as being able to move the wood around before and after it's split.
/ 3pt or Stand Alone Splitter #54
cept tractors are designed for many 1,000s of hours with proper maintenance. running a splitter for a few hours a year is nothing. i worked on a farm that hooked a belt drive to an older diesel tractor to power a well pump. it ran for days. that tractor has done this for many, many years.
/ 3pt or Stand Alone Splitter #55
I prefer a stand alone for the plane and simple reason I may want to use my tractor for something else while splitting wood.
/ 3pt or Stand Alone Splitter #56
While I’m splitting wood........I’m too busy and only one dimensional, so I find it hard to do other work with tractor. :LOL:
just pulling your chain.
/ 3pt or Stand Alone Splitter #57
I went for the stand-alone splitter. I think it also depends on how you split. I take my splitter to the site vs. dragging the large pieces back to a splitting area. This lets me vertically split the massive pieces into more manageable pieces. I am trying to find ways to touch the wood less. I went from unhooking the splitter and transporting in the dump bed of an RTV and stacking at the house to now dropping off some IBC totes and bringing the wood back stacked and ready to store. Transport is slower, but there are less trips so it kind of depends on how much wood is involved. The speed of the split was never my concern as I don't do that much. With the stand-alone I can use either method just fine. There isn't that much maintenance on the engine in my mind at least.
/ 3pt or Stand Alone Splitter #58
Splitting into my half cord boxes, saves a lot of handling of splits,
Then being able to move that box/splits, with a tractor is another back saver!
SR
/ 3pt or Stand Alone Splitter #59
I heave a stand alone splitter and am quite happy with it's fast cycle time and vert/*** splitting.
Use the tractor to move wood to splitter from pile and move split wood to storage.
I could use my lawn tractor to move the wood (only other device I have with dump capability) and the tractor to split, but I don't see an advantage.
One more motor is work, but frees my tractor to be active during splitting and moving.
/ 3pt or Stand Alone Splitter #60
I don't agree. I use a three point splitter and wouldn't even consider a standalone, just like I use a PTO generator to run the house when the lights go off. Not having to deal with another small engine is important. The splitter (likewise generator) can sit a year in the shed and requires NO attention. I use the the bucket to move wood just fine when the splitter is mounted. It's a great counterbalance to loaded front forklifts. So if you have the hydraulics already installed like I do to run my hydraulic toplink (which I also heartily recommend), a three point splitter is a no brainer.
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
40in. Skid Steer Tree Spade (A65640)
40in. Skid Steer...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
