3Pt log splitters
   / 3Pt log splitters #1
Rowski
Veteran Member
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
My father is looking to get a log splitter to mount on the 3pt hitch. We have a local chain saw shop that sells Iron & Oak splitters. We like the looks of the TMVH03 (horizontal/vertical splitter that runs of from the tractor hydraulics. According to the specs the beam hieght for splitting in horizontal mode is 30" high.
My father claims that the 30" hieght is to high? I feel that working at 30" would be more comfortable?
Any thoughts?
This isn't for commercial work.
Thanks...
   / 3Pt log splitters #2
</font><font color="blue" class="small">( I feel that working at 30" would be more comfortable )</font>
I agree with you.
I recently bought a three point splitter from Norhtern Tool. Mine is strictly horizontal and the height is adjusted by the three point hitch position control. I find that the only time I lower it from full height is to load a heavy log. As soon as the log is in place, I raise it. Much easier on my back.
   / 3Pt log splitters #3
   / 3Pt log splitters #4
I purchased a Horizontal/Vertical log splitter from TSC, and according to the manual, the hieght is 42 inches. I find this hieght to be quite comfortable to work with. I am 6 foot tall an I only have to bend over to pick up the logs to place them on the splitter. The only time I use the splitter in vertical mode is when the log is to heavy to lift .
   / 3Pt log splitters #5
I looked at the Timber Wolf 3PH log splitter a few months ago. It had a PTO powered hydraulic pump so you didn't have to have any remotes to operate. The price however was a little on the steep side I thought.
I ended up purchasing a stand alone splitter, rather than putting the hours on the tractor engine and hydraulics I would rather put them on the 6 HP Robin engine, splitter is not hydraulic operated. Something in me does not like to hear the tractor sitting there at a high RPM not moving for any length of time.
The work table height on my splitter is just under 36 inches which is very kind to your back. Any real heavy piece can be lifted by the tractor FEL and rolled on if necessary.
I looked at the TSC splitter last week while visiting Florida and it was a nice looking unit.
Randy
   / 3Pt log splitters #6
Get the stand alone unit. Then you can use the tractor to move the logs and loader to move split wood.
   / 3Pt log splitters #7
</font><font color="blue" class="small">( Get the stand alone unit. Then you can use the tractor to move the logs and loader to move split wood. )</font>
While this is true, it also means you have yet another small engine to waintain, winterize, and annoy you in general. Personally, I'd rather deal with one really high quality engine and run everything off that . . . but then small engines and me just don't get along all that well.
Cliff
   / 3Pt log splitters #8
20040701
Hmm, I have also seen the Northern Tool selections. The tractor remote powered ones are a bit lighter than the others. For example you cannot use a 4 way wedge with them.
They also look like they might have trouble with a very big log segment.
We've lots of Isabell wood to split. I've several "hydraulic pumps on wheels" so that is not a problem.
Has anyone actually owned a Timber Wolf or other "premium" splitter and found it worth the extra bucks, etc?
Those of you with Northern Tool/TSC pto or remote powered splitters, what is your advice? Anyone use Northern's pamphlet to build their own?
Jim
in VA
/forums/images/graemlins/confused.gif
   / 3Pt log splitters #9
A friend of mine has a stand alone Timber Wolf that he has owner for around 15 years. In that time he has replaced the engine once (recently) and the directional control valve.
My mother has owned a Ditter hydraulic splitter for at least 16 years, it got a new engine last year. This seems like a good service life a splitter. Both split on average 12 - 16 cord of wood a year, this includes friends who borrow them.
I purchased a Super Split a few months back, they are on the expensive side. However, going on the testimony of those who use them the process 100+ cords of wood per year for over 15 years without issues I felt it was a good investment.
Besides the cycle times are very fast, 3 to 4 times faster than hydraulics. I still think the saying is true, you get what you pay for.
Randy
   / 3Pt log splitters #10
Your tractor needs to pump out AT LEAST 12-15 GPM for a minimal efficiency,otherwise you will need a costly PTO driven pump. I share a standalone unit with a farmer friend , he owns large AG tractors and even he finds a hydraulic driven splitter way too slow and his tractors flow something like 20GPM.
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
206707 (A58375)
206707 (A58375)
1000000 (A47477)
1000000 (A47477)
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
Kubota L3130 (A53317)
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
