3pt log splitter-practical with Sub CUT?
   / 3pt log splitter-practical with Sub CUT? #1
SwampKing
Bronze Member
Mid-Atlantic Region
MF GC2610 TLB
I'm thinking of buying a 3 pt log splitter to do some seasonal splitting. Fireplace my secondary heat source, so I don't use as much wood as others do with wood stoves. After some research, the Speeco sold by TSC seems like a decent unit for the price and my needs.
My main concern is that with my MF GC 2310's hydraulic flow of 6.1 GPM the splitter will work pretty slowly. I won't be splitting more than a cord or two at a time so its not so much a practical concern as much as how annoying it might get waiting for the cylinder to cycle.
If anyone has used the TSC splitter unit (or similar) with a tractor having similar hydraulic flow I'd appreciate your thoughts. Thanks.
   / 3pt log splitter-practical with Sub CUT? #2
Sir,
I have a log splitter like yours from TSC. I use with my Mahinda 2810 Tractor. It works real good, my Tractor has about the same GPM as yours. I split wood for 35 years with a maul. I love my TSC splitter.
Mr poppy
   / 3pt log splitter-practical with Sub CUT? #3
Same splitter here too. I actually have to idle my 45hp tractor down to about 1100 rpm, otherwise the splitter cycle is too fast for me. For home use, I think 6 gpm will work just fine
//greg//
   / 3pt log splitter-practical with Sub CUT? #4
I started with a splitter using the hydro outlets from my tractor, but with the cost of fuel I put a 6hp gas engine and pump on it. I can split about twice as much wood with the same amount of fuel.
   / 3pt log splitter-practical with Sub CUT? #5
Never thought of it that way, probably for good reason. Diesel here is currently within +/- 10 cents of gasoline. At 1100 rpm, my 45hp (diesel) tractor uses less than a gallon for 3 hours splitting. That works out to well under a buck an hour for fuel. Fuel economy on a little MF 2310 should be even better. Is this a hair you really wanna split?
//greg//
Thanks for the input gents.
For my use, cost of fuel is a non-issue. Besides-my hairs are too short to split.
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
Sprayer Cart (A59228)
2014 International Derrick Digger Truck (A55973)
2014 International...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
