Hey, I have a BX24 as well and am considering a 3 pt splitter. Which line did you connect to on the tractor side, the regular return or the power beyond? If the PB is not reconnected will the loader function and the 3PH? I realize your post is old, and I did read many other posts re. PB circuits, but haven't seen anyone discuss what to do when the backhoe isn't installed. Without another cylinder (splitter, etc.) connected when the BH is removed, the tractor's outlet must be connected to the PB inlet presumably to keep the flow going to the next valve. So I am guessing that the return line from the splitter should be connected to the PB inlet at the tractor. Any feedback would be appreciated. Thanks!
Keith
kennyd- in your last post- basically the power beyond loop can be disconnected and reconnected to any open center valve ? then what the third connection on the BX24 for ? same goes for BX25. I am trying to understand the 3 connections on the back of BX for BH. when the PBY loop is disconnected - I would be left standing with 3 hydraulic connections. One for out PBY and other PBY in. and the third is ?![]()
You mean the hose loop side is PB out ?When the BH is removed from a 24, the pressure-in line is connected to the PB line and the tank line is capped. To use this PB path for a splitter, connect the pressure-in to the splitter inlet, and the splitter outlet to the PB.
I thought if open center valve is used, and using the PB connection only the 3pt hitch and FEL will still work?This maintains the integrity of the PB...BUT, there is a caveat. Since most splitter valves are intended to operate standalone, they expect pump pressure on the inlet side, but not on the outlet (tank) side.
What does the WSM say for pressure for PB in?If you use a PB circuit to plumb your splitter, you need to know the splitter valve's max allowable outlet side pressure (mine is 500psi).
On a 24 (for example), the FEL is downstream from the BH (splitter). I can't use the FEL. Before, after, or in a pinch...temporarily removing the splitter from the PB circuit...but not with the splitter connected hydraulically.
Where did you get the coupon from? Was it valid for in-store purchases? I was going to order one from the local store to save on shipping. An additional 20% off would be great!Many thankis for this discussion. I just ordered a Harbor Freight 3-point splitter today ($400 after the 20% off coupon!) and am looking forward to taking care of the rest of my woodpile!
I am trying to understand my system as well since I have BX24 too.
wouldn't the OC valve solve this issue ? I am thinking that since the PB hose have nothing in between the in and out PB a open center valve is the same thing?
...I was hoping to drop the splitter on the ground to pick up the larger pieces.
...you may lose the 3point hitch function to lift. just undo the hoses and you wil return the hyraulic flow to 3 pt.
