3pt lift arm adj
/ 3pt lift arm adj #1
ericbx1500
Michigan
BX2380, scotts 48
I just installed my bb and have a question about the lift arm adjustment. The one arm has a large turnbuckle with a lock nut on top. Is the top adjustment fixed or am I able to loosen the nut and adjust it. I tried and can't even budge it so I took the arm off and adjusted the bottom. This doesen't seem right??
/ 3pt lift arm adj #2
You should be able to loosen the nut and adjust the arm like the top link. Mine is so tight i couldn't budge it with a pipe wrench and cheater bar. I may take it to the dealer for warranty.
/ 3pt lift arm adj
I sprayed some lube on it and I will let it sit over night and give it another shot sunday /forums/images/graemlins/confused.gif
/ 3pt lift arm adj
well letting it soak overnight in breakaway worked. I took the arm off AGAIN and put it in the vise and took a pipe wrench BAME broke loose finally!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/wink.gif
2022 KOMATSU PC130-7 EXCAVATOR (A60429)
2022 KOMATSU...
Case 1020 25ft Draper Head (A61307)
Case 1020 25ft...
Toro (A56857)
Toro (A56857)
2014 Club Car Carryall 295 4x4 Gas Utility Cart (A59228)
2014 Club Car...
UNUSED FUTURE FT15P EXCAVATOR (A60430)
UNUSED FUTURE...
BUNDLE OF METAL FRAMING BRACKETS (A60432)
BUNDLE OF METAL...
