3pt hitch tiller
   / 3pt hitch tiller #1
musselmark
grand tracadie PE
'05 NH TN75DA
Want to build a tiller 6 feet wide or so
Should I go PTO powered or hydraulic. If hydraulic can I just use hydraulics from tractor
TN75. If hydraulic, can motor shaft directly turn tiller
Or should the be a chain drive.
   / 3pt hitch tiller #2
Just buy a GOOD QUALITY 3 point pto tiller...
IF you buy good quality like Kuhn or Howard or the better Maschio models, it will last thousands of acres, with just maintenance and replacement of wear out items.
SR
   / 3pt hitch tiller
Wierd answer to post in the "build it yourself" forum
   / 3pt hitch tiller #4
Not at all, GOOD used tillers can be bought cheaper than building one of equal quality, and maybe the OP didn't know that.
SO I offered a friendly suggestion/opinion.....
I would hope someone would do the same for me...
SR
   / 3pt hitch tiller #5
I'm following. Peaked my curiosity.
   / 3pt hitch tiller #6
The OP is up in a MAJOR potato growing area. What type of soil, how deep, acres you plan on tilling, and reasoning that you want something other than a factory manufactured product? Your tractor would need power beyond to run a hydraulic tiller and you will need some hydraulic cooling if you plan on running it very long too. A 3pt version would be easiest.
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2014 CATERPILLAR...
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A56435)
2025 Wacker Neuson...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A58017)
2017 VOLVO VNL...
