3pt hitch tiller
   / 3pt hitch tiller #1
musselmark
grand tracadie PE
'05 NH TN75DA
Want to build a tiller 6 feet wide or so
Should I go PTO powered or hydraulic. If hydraulic can I just use hydraulics from tractor
TN75. If hydraulic, can motor shaft directly turn tiller
Or should the be a chain drive.
   / 3pt hitch tiller #2
Just buy a GOOD QUALITY 3 point pto tiller...
IF you buy good quality like Kuhn or Howard or the better Maschio models, it will last thousands of acres, with just maintenance and replacement of wear out items.
SR
   / 3pt hitch tiller
Wierd answer to post in the "build it yourself" forum
   / 3pt hitch tiller #4
Not at all, GOOD used tillers can be bought cheaper than building one of equal quality, and maybe the OP didn't know that.
SO I offered a friendly suggestion/opinion.....
I would hope someone would do the same for me...
SR
   / 3pt hitch tiller #5
I'm following. Peaked my curiosity.
   / 3pt hitch tiller #6
The OP is up in a MAJOR potato growing area. What type of soil, how deep, acres you plan on tilling, and reasoning that you want something other than a factory manufactured product? Your tractor would need power beyond to run a hydraulic tiller and you will need some hydraulic cooling if you plan on running it very long too. A 3pt version would be easiest.
8065 (A51572)
8065 (A51572)
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2016 LT63 Towable Light Tower (A51691)
2016 LT63 Towable...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2010 Nissan Sentra Passenger Car (A51694)
2010 Nissan Sentra...
