3pt hitch power down
/ 3pt hitch power down #1
Roadkill95
CT
none now
What has to be done on a bx2350 to make the 3pt hitch a power down also?
/ 3pt hitch power down #2
No regular tractors made in the last 30 years have power down except Belarus from Russia that I am aware of. What are you wanting to do?
Just seems like it would be nice to be able to put a little down force on a rake or grader blade
/ 3pt hitch power down #4
Roadkill95 said:
Just seems like it would be nice ...
You are right that it ‘Just seems like it would be nice’ … It really would not be as handy as gravity, I have used a tractor with down pressure 3pt… very UN-handy… KennyV.
/ 3pt hitch power down #5
I'd bet if you had hydraulic lifting rods, like in a Top 'n' Tilt setup, that it could be done. But I'd personally just add weight to the implement because I'd be afraid that adding downward force at the mid-point of the lower links could bend them.
/ 3pt hitch power down #6
I had an old "power king" tractor that had down force on the TPH. It was OK I guess, but seems like I spent a lot of time with one wheel spinning do to loss of traction because of the down force. I don't miss the down force TPH at all.
ron
/ 3pt hitch power down #7
My old IH300 Utility has downpressure on thr 3ph. But there's also a big pin you can pull out if you just want it to float so you have a choice. It works great for the post hole auger, but I havn't tried the auger yet on my B7800, so I can't say if it's better or not. I can't imagine that downpressure wouldn't always be an advantage with an auger if used sensibly. Only problem now is the 50 yr old tractor isn't as reliable and as easy to manoeuver around as the Kubota.
/ 3pt hitch power down #8
I have had a Ford 8N and now am the happy owner of a BX24. On the Ford I had a rear blade that had some removable suitcase weights. I kept the blade and the weights. I now have a York rake and the blade on the Kubota. If I need a little more bite for either I just hang one or both of the weights on the implement.
/ 3pt hitch power down #9
Isn't this the same as draught control as on larger tractors?
/ 3pt hitch power down #10
Nope… Draft control actually raises the 3pt. when the pull increases past a pre-set point, it is available on most tractors, but most tractors are not used for 3pt plowing, so this has become an option… KennyV.
/ 3pt hitch power down #11
The draft control is standard in larger farm tractors as most all are equipped for three point hitch tillage. As Jerry stated before the only one to have down pressure was from Russia in years. The IH two point hitch did have down pressure and if you knew how to run it you could really do some digging! There are adapters available to make it three point hitch and it is wise to pull the pin to allow the load to not have down pressure! Three point hitch equipment is not designed for down pressure! The tongue between the hitch and the ground engaging tool is normally not strong enough to handle the added weight.
/ 3pt hitch power down #12
I had an IH 300 Utility also. Easiest tractor to change a rear tire on!
Greg
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
FECON CEM36EXC2-FS-XXV-0LPK11 DRUM MULCHER (A64277)
FECON...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
