3pt functionality/control problem?
/ 3pt functionality/control problem? #1
CTyler
Blair, Ne.
L3130
I have a L3130 and am puzzled as to why the fine controll is not there on the 3pt. The 3pt moves up and down ok but small movements are not precise. Take the box blade for example and you want to lift it gradually or just an inch. So I pull on the lever a little bit and nothing, a little more still maybe nothing, a tiny bit more and it jumps 2-3 inches. When pulling on the lever a little I'm talking 1/8 to 1/4 or so. The heavier the load the worse it acts. Its not "that bad" but its mildly irritating.
Why isnt there precise controll like with the loader or my HTL?
Its almost like there is air in it or slight sticking on a valve? However it does this going down as well, jerky not smooth for small movements. It has done this since day one.
Another thing that started recently is the 3pt leaking down. This started immediatly after changing the hydraulic fluid. The 3pt will leakdown an inch or two. This happens slow enough that its not noticable. However when the sensor, valve whatever detects it has moved it jumps back up again.
What detects the relative position on the 3pt? Can the sensitivity be changed? Is there something I can check for these issues or do I need to call the dealer?
Thanks
Chris
/ 3pt functionality/control problem? #2
As a thought, try throttling the engine down. I found that if I run above 2200-2300 rpm, all of the hydraulics are a bit jerky....also, if you are driving, or if you are using other hydraulics then the 3 point hitch will compete for pressure and that could cause some slight problems.
All the rest of the hydraulics are smooth at any RPM just faster/slower. The 3pt is actually slightly better at higher RPM, more responsive at least.
Thought about the hydraulics competing for pressure. Rulled that out by being stopped, stepping on the brake, not using any other hydraulics and moving the 3pt.
Thanks
Chris
/ 3pt functionality/control problem? #4
I have the same problems with my new B7500. I was so use to my older Kubota B6200 that when I spent the big money on a new machine and then I had a hard time spreading gravel because the lift raised too fast. Now thats frustrating!!!!!!! You pull and puul the lever back then all of a sudden it raises like right now.. I found it very hard to feather the control.
/ 3pt functionality/control problem? #5
Have you adjusted the control valve under the seat, you know, the knob to the right as you look down. I was meaning to try it tonight with my weight box to see if it made any difference....got busy puttering in my shop and didn't get around to it......
Hi...
Yea I played around with it. The valve will increase/decrease the travel rate or close it to lock it in position. It doesn't seem to make a difference as far as movement and the control lever. Its like the lever has to move 5% percent before there is enough change to warrant movement and then it moves 5% when you only want 1%.
Thanks
Chris
Dohh...I see your were responding to JBcat.
The valve will help with the speed, mine is usually about mid position.
/ 3pt functionality/control problem? #8
Just got a bulletin from Kubota today. Seems like there's a 3-pt filter that doesn't need to be there and it needs to be removed. Check with your dealer, they should know about it(or will soon). this supposedly affects the 3-pt opp. and may very well be your problem. As for the B7500, this is not a position control hitch and this is just how it is.
/forums/images/graemlins/cool.gif <font color="orange"> Happy Tractorin'</font> /forums/images/graemlins/cool.gif
/ 3pt functionality/control problem? #9
That filter problem, is that on the 7500 or the 3130???
Thanks - JB
I called the dealer and he read the bulletin but the service dept needs to check it out. They said it sounds like air and/or needs adjustment.
They want to come pick up the tractor which is what I was afraid of. Its great they want to pick it up, thier service is good. Trouble is I'm without the tractor for a day or two. Were doing a lot of dirtwork on the farm getting ready to build a house. I'd prefer to do this myself if possible and save me and the dealer time. Guess maybe I need to talk to the mechanic in the service dept.
Thanks
Chris
/ 3pt functionality/control problem? #11
Well... If you get it done and it doesnt change a thing, I wont have to lose my tractor for a couple of days!!! /forums/images/graemlins/grin.gif
/ 3pt functionality/control problem? #12
My bx2200 has the same jumpy action when trying to lift the 3ph when using a rake or box blade. Its' awful tough to get it to lift just a little for spreading. You can hear the fluid bypassing(?) when you first get into the valve, then up she comes all at once. Throttling helps, but that can be a pain at times. I doubt its' possible, but a flow control valve or better throttling on the 3ph raise portion of the valve would be nice.
DaveL
The dealer picked up the tractor this morning. I'll let you know what they say.
/ 3pt functionality/control problem? #14
I have the same problem on my B7500. I'm a new owner and still learning about it, so I could be wrong, but I'm under the impression the valve under the seat will affect how fast or slow the 3-pt hitch goes down, but won't affect how fast it goes up.
The notice from Kubota on the filter sounds promising. I haven't gotten one yet, but I think I'll research that.
Hi, on mine it will affect both up and down movement.
The dealer called and found a piece of a shop rag or something in the valve. First thing my wife asked, was it blue?
Then my co worker...no faith...LOL! I know it wasn't from me since I used a brake cleaner and then wiped everything down after the filters we on.
That should fix the hicup trouble. Hopefully it will be smooth as well.
/ 3pt functionality/control problem? #16
My new M9000 jerks the 3pt on the way up slightly. I haven't played with it much since it only has 15 hours on it. There was an earlier thread about this happening on an M8200 but I don't know what the outcome was. Maybe this is something all Kubota owners need to check on their machines. Is something wrong here? Minor yes but I expect a new machine to work perfectly. I'll do some more testing on my tractor.
Eric
/ 3pt functionality/control problem? #17
I just got a landscape rake and noticed that my "up" is delayed until it finally jumps up. My weight box does not act that way.
I found that in adjusting the rake I have much better control in letting it down to the proper height rather than raising it to height I want. In feathering off after a run with the rake the jerky action does seem to leave a small mound versus a smooth transition. Maybe it is the nature of the beast!
Well this burns me./forums/images/graemlins/mad.gif The 3pt does the exact same thing and still has the hicup! I specifically asked the service manager about about it to, "Oh yea they checked all that out".
/ 3pt functionality/control problem? #19
On my older Kubotas I did not have the problem. I could feather gravel in my driveway without any problems. Now with my 7500 I end up with humps and mounds all over the place. It can be really frutrating!!!!! /forums/images/graemlins/mad.gif
UNUSED WOLVERINE QUICK COUPLER 4 (A64281)
UNUSED WOLVERINE...
2018 International WorkStar 7500 T/A Matador 4,500 Gallon Septic Wet Vacuum Truck (A61573)
2018 International...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
generator trailer (A61569)
generator trailer...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
