3pt. drops fast....2520
/ 3pt. drops fast....2520 #1
cantbeatadeere
UPSTATE new york
any one with experience, I have a 1970 2520 I just picked up and the rockshaft drops all the way down within an hour under no load......ideas???---thanks!
/ 3pt. drops fast....2520 #2
Pretty common for older machines to have a bad lift piston seal. If there is a flow control valve (drop speed) try closing it all the way with the lift up. If it still drops your lift seal is probably going bad. Mine did that for a few years before I replaced the seal and honed the cylinder. It was a non issue until it began oscillating in use.
/ 3pt. drops fast....2520 #3
Could be faulty RS piston seal,leaking control valves Or leaking thermal relief valve. You could try as Fawken suggested to tighten down rate of drop screw(parts key 8)
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
