3pt. drops fast....2520
/ 3pt. drops fast....2520 #1
cantbeatadeere
UPSTATE new york
any one with experience, I have a 1970 2520 I just picked up and the rockshaft drops all the way down within an hour under no load......ideas???---thanks!
/ 3pt. drops fast....2520 #2
Pretty common for older machines to have a bad lift piston seal. If there is a flow control valve (drop speed) try closing it all the way with the lift up. If it still drops your lift seal is probably going bad. Mine did that for a few years before I replaced the seal and honed the cylinder. It was a non issue until it began oscillating in use.
/ 3pt. drops fast....2520 #3
Could be faulty RS piston seal,leaking control valves Or leaking thermal relief valve. You could try as Fawken suggested to tighten down rate of drop screw(parts key 8)
2011 FREIGHTLINER M2 112 CNG (A59909)
2011 FREIGHTLINER...
New/Unused CFG Industrial QH12R Mini Excavator (A61166)
New/Unused CFG...
2012 International ProStar Truck, VIN # 3HSDJSJR6CN671926 (A61165)
2012 International...
2009 International 7400 Service Truck with Crane, VIN # 1HTWGAAR19J160617 (A61165)
2009 International...
UNUSED CFG INDUSTRIAL MX12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
