If you are talking about a field cultivator, hook the front of the spring on then stick a piece of pipe through the rear of the spring. Slide the pipe over the anchor point and pry the spring backwards. This will stretch the spring out pretty easily. Once you've got it in the right position, use your foot to push the spring off the pipe and onto the anchor.
