3PT Backhoe
/ 3PT Backhoe #1
thetreed1
I am looking at a hardly used 3pt backhoe from Kelley. The docs say that the tractor hydraulics need to be rated at 2000 psi. I cannot find anything regarding that for the CT450. Anyone know what its rated at?
Also, I have rear remotes, so how does a 3pt backhoe work off of the rear remotes? I understand how they work if you have a dump wagon on them or something similar, just pull the lever. What I don't understand is how does the backhoe get its fluid if your not pulling the lever?
TIA,
Tim
/ 3PT Backhoe #2
As far as the hyd. if you dont have a detent in the valves (a locking position) you will have to take a bungie cord and hold them open. As far as a 3pt lift BH i would check if the tractors warranty will be voided if you attach one on your tractor. I know MF will void the warranty if you use a 3pt hoe because you could snap the lift arms or damage the internals in the lift housing.
Jeremy
/ 3PT Backhoe #3
TIA,
Tim
You will either need to install a detend in your remote valve or use a bungee cord. That will allow constant fluid flow.
Now for the backhoe.
I would not buy a Kelly backhoe! (Very week hydraulics)
Nor would I ever put a 3pt backhoe on a tractor.
/ 3PT Backhoe #4
I don't know anything about Kelley BH's but I agree with Rick, I would not put a BH on a 3pt hitch. On my Woods BH80-x, there is a lot of force applied when digging and there is no way I would trust the 3pt hitch to be able to handle that force.
/ 3PT Backhoe #5
If you can buy the BH for a good price it is better than the cheap wooden handled shovels they are making these days. Most BH's can be made to mount on a subframe. To make your own subframe is not that hard if you can weld or do the cutting and have a buddy weld it.
Craig Clayton
/ 3PT Backhoe #6
I agree. 3PH backhoes are hard on the tractor. If you are planning on using it alot, look for a subframe or make that a subframe hoe.
But if only once-in-a-blue-moon use, and the price is right, I'd buy it.
To answer you origional question, your tractor is probabally rated @ around 2400psi. It will work with less, but it will just have less force.
/ 3PT Backhoe #7
If the 3 point arms or mount points fail while using the backhoe you could be thrown behind the tractor or crushed into the tractor. Personally I would not consider a 3 point backhoe for anything more than the softest soil.
/ 3PT Backhoe
Thanks for the replys...my thoughts were the same to build it a sub-frame. And its only gonna cost me around $800. Need to go and check it out first.
I am not planning on digging a foundation with it, just small digging projects around the farm.
Going to need to research detent valves next. :)
JOHN DEERE 4110 TRACTOR (A64280)
JOHN DEERE 4110...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
Service Truck Body (A61573)
Service Truck Body...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
UNUSED WOLVERINE...
