3ph root ripper build
/ 3ph root ripper build #21
What gladehound said:
"I really like that design! Versatile and simple."
^^ X 2
gg
Thanks. I'd love to take credit but I got it as part of a trade deal. Works well though.
/ 3ph root ripper build #22
I like the receiver hitch design and the single ripper. A multi-gang ripper wouldn't be able to up-root tomato plants in my soil. :)
/ 3ph root ripper build #23
Then you need a bigger tractor... ;) ;) :D
One of these would probably work:D
/ 3ph root ripper build #26
LD1, I love the product. But you forgot the cup holder. I'm afraid your drink in that photo won't make it very far without falling off. ;)
On a serious note, I'd love to see some pics of the soil after you've run that ripper through it.
/ 3ph root ripper build #27
finished product
View attachment 444575View attachment 444576View attachment 444577
Tested it out a bit. It dont like heavy sod as it tends to ball up. But dirt it works as expected. Grabs roots nice too. More tractor would be nice, but it does just what I expected it to. Set it to cut about as deep as a disc, and it leaves results that look just like running a disc. Only without the noise and without the disc wanting to throw the back of the tractor around
I know you designed with function over form in mind but... That thing looks bad a**! Like something out of a Mad Max movie.
/ 3ph root ripper build #28
Nice work I need to learn to weld again. This tractor business can get expensive.
/ 3ph root ripper build #29
Nice job LD1:thumbsup: When can I borrow it;)
Little far for borrowing. If you was closer...anytime
/ 3ph root ripper build #31
Ld1 you really do quality work. Did you ever put a log lift on your splitter?
Nope, and no plans to either. If the wood is too big to lift, I'll use the other splitter vertical or rip them with the saw
/ 3ph root ripper build #33
I use my log lift all the time. Would be lost without it. Even stack smaller rounds that need split on it so I'm no going to the block pile for each piece.
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
EZ Trail 3400 (A63688)
2022 EZ-GO ELITE...
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
